AX-12
Dear members,
i just want to ask you how and where to put the code to run the AX-12 using· parallax demo board ( spin language )
Thank you in advance
If you are writing in SPIN language then it definitely goes in the Propeller forum.
Computers are microcontrolled.
Robots are microcontrolled.
I am microcontrolled.
But you·can·call me micro.
If it's not Parallax then don't even bother.
I have changed my avatar so that I will no longer be confused with others who use generic avatars (and I'm more of a Prop head then a BS2 nut, anyway)
i got the parralax demo board from AX-12 from crust crawler. and i downloaded the dynabus program which containes a library for AX-12.
after programing the chip. i dont know how to comunicate with the servo and send the instruction packet.code ( 0xFF 0xFF ID instruction .........)
i can read the status packet using the test terminal. that reads that the servo is off.
my question is how cn i use the the dynabus code to control the AX-12.
please reply ASAP
thank you for your help
regards
Want to·experiment with the SX or just put together a cool project?
SX Spinning light display·
