making your own printed circuit boards?
Hi guys I was wondering I have been wire wrapping and bread boarding my projects forever but the more robotic stuff I build the more its clear to me I have to use circuit boards I never dove into the how to but I found a lot of stuff online
are most of you using etching solution? My board are going to be very basic 2 layer at most is this the best way use chemical etching and then use a drill to drill out the holes?
Is there a package I can buy with all the stuff in it that anyone can point me to.
do the search thing here - we've had several recent posts about different ways to make boards.
You can do simple ones with etch solution - RadioSnack has some kits for this.
But you can also use muratic acid (dilute hydrochloric acid)... and there was a post a few days ago to a youtube (or instructables?) on putting the board in a bag with some hot water and powered chemicals (perchlorate, maybe).
Single and double boards are pretty easy to make as long as the traces aren't too thin and the pad spacing not too dense... you'll get plenty of help here too, when you need it.
- H
considering all the nasty chemicals you have to use and store around your living space, and considering you then have to figure out a safe place to dispose of them (don't dump them out your back window), not to mention the stink, etc. why not use a service, like expressPCB, or any of the countless other services that people will soon suggest? I'm not very experienced when it comes to electronics, but I've been able to get some impressive (to me) results from these guys:
www.expresspcb.com/
I use Eagle, and simply go on Sunstone.com, place an order and upload the Eagle .brd file (no hassle with exporting gerbers). 3 days later you have first rate boards at your door Fed Ex.
Post Edited (Todd Chapman) : 9/12/2009 12:50:34 AM GMT
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Leon is a PCB god!!! He could probably do 4 mil traces if he had to. But he's had a long time to perfect his craft. I gave up DYI PCBs years ago and have never looked back. It's just not worth the hassle: the stink, rusted tools from the vapors, stains on your clothes and counter tops, and disposal issues — not to mention the investment in tools, materials, and time. The proto houses are hungry for your business and have set their pricing accordingly. Take advantage of them! (And if your significant other expresses concerns about the minute cost, be sure to mention the stains!
Etching isn't particularly messy - I use a plastic food container in a old washing up bowl with about 1" of very hot water in it in the kitchen sink. Continuous rocking of the inner container etches a board in about 5 minutes.
Anyone using similar equipment and materials should be able to achieve the same results quite easily. The only variable is the UV exposure, and that is easy to ascertain with the old photographic test strip technique, or a Stouffer test gauge.
This group is very useful:
tech.groups.yahoo.com/group/Homebrew_PCBs/
Lots of members have reported similar results.
Leon
Post Edited (Leon) : 9/12/2009 2:00:57 AM GMT
You're in the UK. To be fair, is your penchant for DYI PCBs more a result of necessity or simply love of the craft? Here in the U.S. and Canada, we have abundant cheap proto PCB houses that compete strenuously for our business, rendering the DYI approach virtually moot. Not to disparage the UK or the PCB fab resources available there — far from it: but I was just wondering, since this comes up so many times with predictable responses from the "usual suspects" (myself included).
Leon
Post Edited (Leon) : 9/12/2009 2:08:40 AM GMT
Well, okay, fair enough: that's comparable to the situation here. I use the three days' hiatus to take a breather from the design work, to attend to neglected business, and to order parts. But I typically have enough overlapping projects that the "pipeline delay" doesn't matter.
And in what amount of time do you like non-working prototypes?
Now I build boards even leon couldn't make by hand. Much better to pay $200 for a panel of boards then deal with hassles of chemicals. Delay in getting back is only bad thing.
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
$200? ouch....
Just so you don't get sticker shock, you can get 3 identical boards, 2.5 inches x 3.8 inches made by the guys I mentioned earlier for about $65, which includes getting delivery within a few days. So if you're interested in something relatively modest, it's a reasonable place to start. Also note, you can cram a lot of functionality onto 9 square inches! They have software you download for free for a PC and it's fairly easy to learn. Look at their MiniBoard service.
www.expresspcb.com/ExpressPCBHtm/Specs.htm
These "bare bones" boards arrive brown (or shiny silvery if you have a ground plane all over them) with the traces visible. At the aforementioned price, they do not have the solder mask and silkscreening, but that will not affect the functionality, though it might make it more of a challenge if you plan to use surface mount devices with teenie-weenie pins. You can pay more money and get the silkscreen and soldermask so the boards look totally professional, but it will, of course, cost more money.
I think there's a lot to chose from if you shop around.
good luck, have fun, and remember to eat your vegetables!
I have been using ourpcb and so far I like what I have received. I can get soldermasked and silkscreened boards for less per board than expresspcb charges. You don't have to panelize them either.
How do you make vias on your 2-layer boards?
BH
Leon
BH
That's 100 boards
Leon
Right now, I'm either bread boarding, just hooking stuff up, or using matrix board and wires. Good for simple, small things.
Would it then be safe to say making your own boards makes sense, if:
-you enjoy the craft,
-want the experience,
-have a time issue,
-on a tight budget,
-circuit complexity is low to moderate,
-chemical handling is not an issue,
-physical dexterity is adequate.
Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
Safety Tip: Life is as good as YOU think it is!
PG
Awesome! Who's the service???
They will do for $110 if you don't need rohs compliance and quite as small via.
Get electrical testing worth the money.
My super prop is going to be about $1000(waiting for quote) but that is 6 layers 4mil trace/clearance and 8 mil via. And blind via.
4pcb.com is good price for serten sizes but shipping to canada is to expensive.
You can also become a "PCB God" with about a $25-$40 investment in "practice" materials... All you need are transparencies, HCl/H2O2, photo-resist board(found at Fry's Electronics or elsewhere), a UV or black light, and an inkjet printer. I'd be happy to guide you through it.
Leon
I was wondering whether anyone could suggest a kit I could get to start learning how to etch boards. I know RipoffShack used to have a kit, but it was a ripoff (... hence the name) and I have not seen it on their website, or in their stores of late.
Forest
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
*-NEW-* SD Card Adapter·Now available!· Add extra memory to your next Propeller project with ease!
The problem normally is not etching but getting a good transfer method, i.e. getting a well done mask over the bare copper. photo-sensitive boards and an UV lamp are the best and you can get down to as Leon said few mills.
Drilling also consumes loads of time specially if your drill has to be used with you hands. Get a proper stand, it saves time.
When I was around 15 I used to make many boards a week but nowadays I prefer to use the services of some pcb-making company: my time also counts and I do not have 8 hs a day to do my hobby as when I was 15. Waiting 15 days for a board is ok. I have to get the components and find the errors I put in the board
Depending on you country you can pay to get them disposed properly (i.e. someone puts them down the drain for you).
Visit some of my articles at Propeller Wiki:
MATH on the propeller propeller.wikispaces.com/MATH
pPropQL: propeller.wikispaces.com/pPropQL
pPropQL020: propeller.wikispaces.com/pPropQL020
OMU for the pPropQL/020 propeller.wikispaces.com/OMU
