Serial SX-Key ????
Hi guys I am brand new to the SX and have recently acquired an SX-Proto board I was also give given a programing key to go along with the board but I can not find info on it
Its a SX-KEY has the 4 pin female connector on one end for the board but the other end is a 7 pin Serial connector ,, can I just use the software for the USB Key?? will the IDE still work the same its defiantly a Parallax SX-Key it says it right on it but even checking the discontinued section yielded no help thanks guys
