MOVS and MOVD — Parallax Forums
MOVS and MOVD
Bobb FwedBobb Fwed Posts: 1,119
edited 2009-09-11 23:03 in Propeller 1
I am trying to reset an instruction's destination and source. I am hoping there is a way to set both at the same time.
To progress it, I am adding 1 << 9 + 1 to the value, but to set it back to the original location what's the fastest way?
Here is clips of what I am doing:
timeh         IF_Z      ADD     time, pinhighs
                        ADD     timeh, dsplus1
                              [i]_with_[/i]
reset                   MOVD    timeh, #time
                        MOVS    timeh, #pinhighs
dsplus1                 LONG    1 << 9 + 1                                      ' destination and source plus one value
pinhighs                LONG    0 [noparse][[/noparse]31]
time                    RES     31
Can I do that reset section in one instruction? It is is a known number of additions. So I guess I could SUB it...
April, 2008: when I discovered the answers to all my micro-computational-botherations!
    edited 2009-09-11 15:54
    Can't you just store the original instruction, then move it, when it's time for a reset?
    Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
    Safety Tip: Life is as good as YOU think it is!
  • Agent420Agent420 Posts: 439
    edited 2009-09-11 16:04
    I'm still a bit young in pasm, but that would be my guess.· In fact, that's one of the tricks I picked up studying Chip's vga driver code...
    sub timeh, reset_addr
    reset_addr     long   (1 << 9 + 1) * < # of iterations >
    edit - oops, had reser as immediate
    Post Edited (Agent420) : 9/11/2009 4:09:18 PM GMT
  • JavalinJavalin Posts: 892
    edited 2009-09-11 19:12
    this might help - not sure.
    http://obex.parallax.com/objects/268/
    Example of using movd / movs for self modifying code
    J
    edited 2009-09-11 19:18
    potatohead has the right idea on this one.
  • Bobb FwedBobb Fwed Posts: 1,119
    So something along these lines:
                            MOV     timehbak, timeh
    loop
    timeh                   ADD     time, pinhighs
                            ADD     timeh, dsplus1
                                  [i]_with_[/i]
    reset                   MOV     timeh, timehbak
    time                    RES     31
    timehbak                RES
