Proteus 7 Professional does anyone have a library with the prop chip??
Hi guys I am running Proteus 7 Pro I have the Library file for all the Parallax Basic stamps but I do not have the prop chip or any of the SX stuff does anyone have or know where I can get the files??
thanks
thanks
I have mentioned to some guys to write Propeller emulator for Proteus.
But one of them said ... If You pay .. I can write.
Else You can't find any Propeller Library file for Propeller ... Not sure on SX ... maybe on other forums
Nothing is impossible, there are only different degrees of difficulty.
For every stupid question there is at least one intelligent answer.
Don't guess - ask instead.
If you don't ask you won't know.
If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
Sapieha
If just the footprint, then there should be a method to create the footprint. In Protel (which I use) you can make a footprint for a PLCC which specifies the number of pins, the distance between the centres of the pads, both horizontally and vertically, and the width and length of the pads.
The specification from Parallax for the pcb layout for the Prop has quite largish (long) pads which make it relatively easy to hand solder.
Attached are the calculations for pad sizes. The prop recommended pad sizes give 0.5mm of pad outside the leg. For hand soldering, this dimension depends on how well you·can solder (using a fine tip and temperature controlled assumed). Solder wick is your friend to remove the excess solder and any bridges between pins. You really need to use solder paste. It can be done with fine solder, but not a good outcome - probably OK for 1 pcb)
· Home of the MultiBladeProps: TriBlade,·RamBlade, RetroBlade,·TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
· Search the Propeller forums·(uses advanced Google search)
It is not problem to make footprints else SCH libry parts in Proteus.
Most footprints exist already with ohter parts.
It is Simulation models that are problem
One of programs that are posible to convert to simulations model for Proteus is "Gear" run kernel for Propeller's CPU
With some mods to handle In/Out signals that Proteus ned for comunication betwen Simulations model and Proteus GUI
Regards
ChJ
Sapieha
