AssemblyToggle.spin
Hi , I have an adaptation of AssemblyToggle.spin where instead of xor'ing outa with "Pin" I am xor'ing outa with a·constant called "sData" trying to·toggle output 17.
My adaptation works the same as AssemblyToggle.spin with the exception that there is a long delay before it takes off , maybe 30 seconds.
Can someone explain why I have the delay at start up and what I have wrong or need to do to make the toggle start immediately.
I'm trying to figure out how to mask the outa register in different ways
Jeff T.
CON _CLKMODE = XTAL1 + PLL16X _XINFREQ = 5_000_000 Pub main cognew (@myasm,0) dat org 0 myasm mov dira, direction mov time,cnt add time,#9 mov outa,sData :loop waitcnt time,delay xor outa,sdata jmp #:loop direction long |<17 sData long $AAAAAAAA delay long 6_000_000 time res 1 fit 496
Jeff T.
Try a larger increment to "time". I'd try at least 15. There's 1 or 2 needed for the "mov time,cnt" to finish, then 4 for the ADD and 4 for the 2nd MOV and probably 5 for the WAITCNT to start waiting.
One "trick" is to add CNT as the last step before the WAITCNT like
mov time,#15 mov outa,sData add time,CNT loop: waitcnt time,delayPost Edited (Mike Green) : 9/10/2009 7:22:46 PM GMT
The original AssemblyToggle.spin from the Propeller Manual had " add Time, #9 'Set minimum delay here " which didn't make sense to me at the time but is a little clearer now.
In my adaptation I tried #15 and it worked fine.
A good lesson for the day.
Jeff T.
