Communication conflict
I can't get my BS2 to establish communication with the debug station. I know the stamp is working and communicating via RS232 because I can open the MS HyperTerminal in Windows and receive data from the BS2 program I previously installed. I also have a second BS2 and carrier board that has never been programmed that will not communicate either. Does anyone have any insights as to possible communication conflicts that might be present? The identify command doesn’t recognize the presence of the BS2. When I previously programmed the Stamp, I had intermittent communication problems. I'm running windows XP.
This assumes you are using a USB converter and that you have also downloaded the correct Parallax driver. Generic Windows USB driver won't work.
Cheers,
Tom Sisk
http://www.siskconsult.com
If the IDE connects to the stamp, it WILL 'reset' it (using RTS). The "identify" should definitely find the stamp at that point.
The IDE is very well behaved under XP. You haven't added software to the computer, have you? Thinking of some PDA software that autosyncs your files when you plug it in.
As a last resort, un-install the IDE and do a fresh installation.
Tom Sisk
