Total Newb - Well, Sort Of
Hello,
I recently ordered a Boe-Bot (it hasn't arrived yet) and I thought that might be a good way to begin the journey - I've always wanted to learn how to use robots - now, I'm finally fulfilling a dream.
For the past two years I've been playing around with the NXT's and I am very much looking forward to learning more about robots.
Ironically, I teach high school students Engineering Drawing & Design classes and I recently decided to sponsor the Robotics Club - a first at our school. I have always loved computer programming, mechanical stuff, radio controlled anything, and challenging projects.
I hope the Boe-Bot will be fun, educational, and help introduce me to a new level of robotic challenges. Ultimately, I plan on creating some really cool stuff. Also, I hope I can take this knowledge and share it with my students - they are excited about robots - we had our first meeting this afternoon.
Last weekend I cleaned out a section of my garage and dedicated it as my "robotics lab." I have obtained some tools - any suggestions for "must have" list of tools? I purchased a variable speed Dremel, and I already own a digital voltage meter (it's cheap). My soldering iron is a lousy piece of junk, so, I'll need a new one.
Scope
[noparse]:)[/noparse]
Scope
Don't forget the hand tools ... screwdrivers, needlenose pliers, a good wirecutter and wirestripper. Make sure you get a PING and the servo bracket that goes with it. You'll want to add that to the BoeBot. You might want to get an Easy Bluetooth Module so your BoeBot and your PC can communicate while the BoeBot is roaming around.
If you are willing to go on to the next step, you should get a drill press, a small cutoff saw, and an adjustable power supply.
Finally, the most important thing is a radio or computer for music.
Those are pretty much the things that I use on a regular basis besides the Dremel and soldering iron.
I am one of those who enjoys building things with my hands and am against buying new items at a higher cost when I can find something at a junkyard or thrift store for much cheaper. If you find you have students who are good with their hands as well, you might see if they want to try welding together a frame and build a custom robot from the ground up.
You ask what kind of tools you need, and I'm not sure if I'm the best to give it to you since I am not sure of your needs, but I will tell you what works for me:
-Butane soldering iron--allows for 30-90 amps. It's great to be able to do soldering work where you need it instead of having a cord, and it doesn't take long to heat up at all, while allowing for you to decide how hot you need it.
-Desoldering iron--great for when you make mistakes or wish to recycle parts out of old electronics.
-Mixture of transistors for controlling motors
-Mixture of resistors
-Mixture of capacitors
Everything else is up to you, but these are just what seems to help me the most.
PG
Is a DMM a digital multi meter? If so, I have one will probably get me going for now.
Why the adjustable power supply? Do you mean something I can use to get various DC voltages?
I used to rewind commercial electric motors - it wasn't cool to use wire strippers (ha). I think these tiny little wires used w/robots could be rather difficult to strip without pulling out wires - I'll bite the bullet and get some strippers - but, don't tell the guys I used to work with (ha).
Small cutoff saw? Like one of these:
Does Parallax offer customers the PING, servo bracket that goes with it, & Easy Bluetooth Module?
I'd also like to find some sort of assortment of fasteners, and other items used to build or modify the chassis - good for spares when not tinkering.
And a pick? Would this be similar to an ice pick?
Scope
A pick would be more like a dental pick. We're really talking about small tools mostly here (for working with little electronics parts). The bigger stuff would be for building the mechanical stuff for a robot.
PG
The adjustable power supply is to quickly and easily choose any voltage (within a limit, 20V is usually fine) and to see how much current is being used by the device under question. I love mine...
I use a small saw from harbor freight jerry rigged with a metal cutting disk. It's about 3" and it works fine for cutting the 1/2 aluminum angle iron that I use and other small metal bits.
For fasteners, #2, 4, and 6 should be fine for the electronics side. I use #6 for mechanical too, but I don't build anything big.
Like Mike said, for electronics you want to think small. I forgot to mention this, but you'll also want at least three lights: room, left and right. If you only have two then you'll have shadows on your work.
welcome!
Instead of (or in addition to [noparse]:)[/noparse] that cut off saw, you might consider a *portable* bandsaw. I got one at a pawn shop many years ago for about 1/3 price. When I'm metal working, it's always within hands reach. As Pi Guy says, bandsaws make a much cleaner cut than an abrasive cutoff saw. <-- the cut wheels can (and do) break apart violently on those. Of course, if you just need to hack off a chunk of metal, then it's OK. But, you know, I have both - and I haven't used the cutoff saw in > five years. [noparse]:)[/noparse]
@SRLM - surprised Sandgrouper mentioned hot-glue, but you didn't - isn't it one of your favorites tricks of the trade?
"one of those wrentches with an adjustable worm screw" - you mean a pair of "vice grips" ? Yeah - two or three of them even!
Scope - you might also find two-part epoxies quite useful.
As SRLM said, a wide assortment of fasteners goes a long way. I'd go up to #8 and #10 in multiple lengths, with a box of nylon lock nuts, and various widths of washers.
Did we mention *clamps* --- yes we did --- clamps are like money - you can never have enough!
One other item I could never do without again: a "Drill Doctor" for sharpening drill bits.
You're in the right place for great, friendly assistance!
Cool avatar, BTW.
cheers
- Howard
Since you are doing this with many robots in a classroom, I also advise getting a lot of ir emitters/receivers so you can experiment with wheel encoding and line following among other things like communication between robots.
PG
Honestly, I don't use hot glue that much. I haven't really felt the need for it that much, but I know some other engineers who use it all the time for a quick hold.
Vice Grips are good, but what I meant was "adjustable wrench" (thank you google!): en.wikipedia.org/wiki/File:Kluc_nastavitelny.jpg
Post Edited (SRLM) : 9/13/2009 12:45:50 AM GMT
Fortunately I have several of these items already. I worked more today on the Boe-Bot and also on the SRL (Scope's Robotic Lab) in my garage. I'll keep my list in my pocket - whenever I have an opportunity to stop someplace and pick something up I will (wife goes to get milk and bread - comes back 27 minutes later - I'm waiting in the car - DOH, I could've sneaked over to Home Depot and grabbed some clamps).
The avatar is a CAD model I created using Google SketchUp. CAD modeling is one thing I am somewhat proficient at doing. I used to teach Pro/E, AutoCAD, MicroStation, several others. I highly recommend SketchUp for anyone - it's far better than many realize and yes, still totally free. Some of its most useful features are often undiscovered. I have a photo of my shop around here somewhere . . . it's coming along.
Happy roboting (?),
Scope
Post Edited (Scope) : 9/13/2009 1:11:26 AM GMT
I think a Dremel or similar rotary tool is extremely quick and versatile. I also recomend a set of jumper wires with alligator clips, and a NiCd/ NiMH battery charger that can handle different size batteries. You should avoid using throw away batteries as much as possible on your robot.
Have fun!
My Robots
Today, I was thinking about how all my life I've always enjoyed building stuff - I've always loved radio controlled cars, helicopters, and airplanes.
Today, I had the "robot epiphany" - this hobby contains everything I've always enjoyed: technology, mechanisms, computers, problem solving, building stuff, and programming. I mean, c'mon, what's not to love about robots?
Just wanted to share my joy.
And, ya, I know I'm "preachin' to the choir."
Happy roboting,
Scope
A side note, but I think there is a bit of danger in that line of thinking (finding support for your arguments). I used to spend my hobby time working on my garden railway, and I subscribed to the hobby magazines. Every once and a while an author would comment that the hobby has everything: modeling, electronics, gardening, history, computers, etc. In short, no matter what hobby you join you'll probably always say "This is great because it has A, B, and C, all of which I enjoy". Still, that doesn't make it any less fun...
PG
Tia'Shar Manetheren
PG
Jax
If a robot has a screw then it must be romoved and hacked into..
Tia'Shar Manetheren
PG
