Stepper software for prop chip — Parallax Forums
mikedivmikediv Posts: 825
edited 2010-05-03 13:28 in Propeller 1
Hi guys does anyone have a decent program for driving a 6 wire unipolar stepper motor I have a design I am working on and wired up a ULN2803 to a 6 wire Unipolar stepper motor but I can not find any code for the prop that I can use to test this or try and learn how to do it myself if anyone has anything they are willing to share I would be very grateful.
  • W9GFOW9GFO Posts: 4,010
    edited 2009-09-10 00:56
    I don't have the program you're looking for but I do have some extra periods and commas that I'm not using, you can have some. ..........,,,,,,,,, smile.gif
    Rich H
    The Servo Boss, a 12 channel servo tester kit from Gadget Gangster.
    edited 2009-09-10 01:36
    Mike,
    Running a unipolar is very easy as you just need a step sequence a bit like this: (assume 4 coils labeled A,B,C,D)
    Forward: Drive A, wait, drive B, wait, release A, wait, drive C, wait, release B, wait, drive C, wait, release B, wait, drive D ..... and so on
    Reverse: Drive D, wait, drive C, wait, release D, ....... and so on
    This is the half-step method that pulls the armature to the half-step position when both coils are driven. Of course when you forward or reverse you simply drive the adjacent coil of the one that happens to be driven. Use an index of 0 to 7 that wraps around for this. The wait period can be made variable to allow for acceleration and deceleration.
    *Peter*
    P.S. index has to 8 steps which can lookup a table to decide which coils to drive.
    edited 2009-09-10 07:04
    Hello,
    I found this animated schematics
    that show the sequence how the coils have to be switched on/off
    this one seems to be a 6-wire unipolar on the page it is called "unipolar halfstep"
    to drive the steppermotor you can define an array of bytes that contains the bittpatterns
    according to the bitpattern shown in this animation I post some lines of code that show the principle
    (edit if you don't add blanks between square-brackets this "highly sophisticated" forum-software takes them for changing the fontsize)
    Var
      byte BitPattern[noparse][[/noparse] 8 ] '8 elements accessed by index 0 to 7 NOT index 1 to 8
      long count
    Pub Demo
      BitPattern[noparse][[/noparse] 0 ] := %1000
      BitPattern[noparse][[/noparse] 1 ] := %1010
      BitPattern[noparse][[/noparse] 2 ] := %0010
      BitPattern[noparse][[/noparse] 3 ] := %0110
      BitPattern[noparse][[/noparse] 4 ] := %0100
      BitPattern[noparse][[/noparse] 5 ] := %0101
      BitPattern[noparse][[/noparse] 6 ] := %0001
      BitPattern[noparse][[/noparse] 7 ] := %1001
      DirA[noparse][[/noparse] 0..3 ] := %1111
      repeat
        repeat count from 0 to 7
          OutA[noparse][[/noparse] 0..3 ] := BitPattern[noparse][[/noparse]count]
          waitcnt(ClkFreq + cnt)
    Steppermotors and steppermotor cicruits are much more variable than f.e. the I2C-Bus
    You have 4,6,8 coils, 4,6,8 wires, unipolar and bipolar types
    This means there can't be one universial object "steppermotordriver" that suits to them all
    Some code just puts out step and direction to a controller who does the details of switching the wires
    Some other code does the switching of the wires like shown in the codesnippet above
    here is an article stepping out with spin
    that shows some code how to do it on a level a little above what I have shown in the code snippet
    best regards
    Stefan
    Post Edited (StefanL38) : 9/11/2009 7:22:56 PM GMT
  • Agent420Agent420 Posts: 439
    edited 2009-09-10 13:15
    Depending on the size of the motor and the intended application, you may want to investigate some other driver circuits...· the 2803 will suffice as a simple driver for small motors requiring low torque, but if your motor requires more than 500ma you'll want to move onto something like the L293 or even more advanced.
    The controller logic needed for steppers is rather simple pattern based sequencing, similar to what is posted above.· You just need to keep repeating the patterns in the desired direction to move the motor.· Where it becomes more complicated is controlling the current to the motor itself.· As steppers are obviously magnetic devices, the primary factor in their performance is current.· It is quite typical to drive steppers with voltages much higher than what is printed on the motor, and instead control the current using a pwm (aka chopper) technique.· This will significantly improve stepper performance, especially at higher speeds where low voltages can cause the motor to get 'out of step'.
    Here is·a good reference on steppers and control - refer to the 'Current Limiting' section for the topic I mention above.
    Post Edited (Agent420) : 9/10/2009 1:43:50 PM GMT
    edited 2009-09-10 14:02
    It may be simpler in cases where you have 4 bits of output and 8 bit patterns ( 32 bits total - quite common ) as in the diagram StefanL38 posted to use a long to store all 8 bit patterns. That way you can rotate the long 4 bits in one direction and output the 4 bits to go in one direction, and reverse the direction you rotate the bits to go in the other direction.
    edited 2009-09-10 14:28
    ^ That is an excellent suggestion, I have used similar methods with other projects.
    Var
      long BitPattern
    Pub Demo
      BitPattern := %1000_1010_0010_0110_0100_0101_0001_1001
      repeat
        OutA[noparse][[/noparse] 0..3 ] := BitPattern & %1111
        BitPattern ->= 4             ' Forward (<-= for reverse)
  • mikedivmikediv Posts: 825
    edited 2009-09-10 21:25
    Thank you all for the help,, I am attaching my simple schematic of what I am doing . Agent420 I agree an L293 would be a good way to go but I only have ULN2803 chips at hand and I just wanted to do a proof of concept first.
    I found this code from Ray Allen he is one of the resident genius's here but as hard as I have tired to modify this to work my stepper only hums or buzz but does not move. The steeper motor I am using are 1 amp but by doubling up the ULN2803 outputs it should be able to handle the no load power for enough time for me to see if they will at least step. When I refer to they I am using/trying different steppers but only one at a time
    Thanks. StefanL38 that's a very interesting animation thank you for taking the time to find it as well as the rest of you.
    Peter Jakaci do you mean I should build a logic table ? If yes how many bits should it be I read Kwinn post on 4 bits but this is where I get confused.
    edited 2009-09-10 23:14
    Mike,
    For starters the ULN2803 is not really able to handle 1 or 2 amps total, there is an absolute maximum power rating of 1.47W for the DIP package. What happens is that each darlington will only saturate to around 1.5V @ 500ma each which means just one coil will push this past the limit. BTW, the recommended rating is 0.76W. Bear this in mind when the lid of the chip goes pop and lets all the magic smoke out. It's not really good enough to say that's all you have but if you really really must then piggyback another chip on top. Far easier (in this case) just to use little TO92 transistors (low-sat) that can handle a few amps easy.
    The code examples that others have given should help you along, I was trying not to do it for you as the sequence itself is very simple, you just need to understand it. You have your Spin compiler ready and waiting for you to type in a little test sequence, even as primitive as the sequence that I outlined, so what's stopping you?
    *Peter*
    edited 2009-09-10 23:24
    Peter thanks same thing I used the examples but for some reason my steppers just hum/buzz I can not get the shaft to rotate even if I change the values ????? I know the steppers are good. I put the signals on my scope and I can clearly see the prop is outputting
    a square wave signal and I am sure I have the pins right what could I be missing I am obviously missing somehting simple , Oh Peter according to the data sheet the way I have the pins doubled up it states it can handle 1 amp I agree with you this is not the way to go forward but I just want to get my code working to some degree
    edited 2009-09-10 23:37
    The 1 amp thing is just a warning, by all means proceed but don't be surprised especially as you can also be handling 2amps with 2 coils, but it's the power dissipation that's a big problem.
    The code you posted shows you trying to do microstep so just comment this one out and uncomment the full or half step. Make sure your coils and code correspond so that the coils are driven in adjacent sequence. If in doubt, swap a couple around [noparse]:)[/noparse]
    *Peter*
    edited 2009-09-10 23:49
    Hello Mike,
    maybe if you try it in some kind of a single step mode
    with LEDs in parallel to see which coil is switched on/off
    I mean a testprogram where you can step through the sequence by pressing a key
    pressing the key ONE time and take a look how the shaft was turning for some degrees
    pressing the key ONCE again and see if the shaft is turning into the same direction as before or the other
    if so change the sequence
    or a testprogram to switch on/off IO-PIN 0-3 by different buttons to test what happens if a switch on pin 0 and then pin 1 etc. etc.
    best regards
    Stefan
    edited 2009-09-11 00:11
    Peter thank you again Stefan that's one of those why didn't I think of that- using LED's is a perfect idea I get what Peter is talking about but with the leds I can actually see what is happening awesome thank you guys I wish I could just use servos they are so much easier
    but I have these really big steppers I even have a couple 20 amp jobbers its the timing I am having the biggest problem with I am just learning how to program period and I am starting with Spin I know this more advanced than where I am at , I am good at blinking Led's and reading toggle switches but the stuff I want to do (build robots) is taking me forever to master spin,,, no knock against spin its awesome but other than some basic literally I am trying to self teach myself and I do appreciate all the help and tips guys.
    edited 2009-09-11 00:43
    Hi Mike, thanks for giving us an idea of where you are at with all this. Since you are learning Spin and you can blink leds you should really treat this as blinking 4 leds in sequence which I am sure you would have no problem with. If you use other peoples code and get it to work with a little bit of fumbling you will not learn as much. Far better to sit down and write just a few lines of code that you can understand and test it, then build on that.
    I am used to programming in Forth where you can communicate and compile interactively with the system and I can testify that this is a very powerful development environment. In a similar fashion though not quite so interactively you can write a line or two of Spin, press F10, yep it looks good, and build on it. So just proceed a step at a time, just as if you are walking for the first time.
    *Peter*
  • w8anw8an Posts: 176
    edited 2009-09-11 23:36
    Mike,
    I was doing the exact thing you are with a unipolar stepper just a couple weeks ago. I have some spin code that will step and run the motor forward and reverse for testing.. I will post if you're interested.
    Steve
    edited 2009-09-12 00:20
    Steve yes that would be great Peter I was just getting ready to shelve this project. I did try all the samples everyone posted here Thank you all again and with my Scope and the LED's it does in fact work I can watch the LEDs sequence but when I try ans connect the steppers
    they just Buzz I am starting to think I am doing somehting wrong with the steppers directly let me explain. I got these out of a large photo enlarger they are Vexta 2 Phase PH 2610 6V 1.8 A
    6 Wire with the help from some of the guys here I learned how to Ohm out the wires So taking 3 of the six I ohm between them and find the common so 10 Ohms between 2 wires and then 4.8 Ohms from the common to either end wire I end up with 2 common wires and 4 coil wires
    I can Ohm them out so I have each Coil you can see from schematic I tied the common wires to pin 10 of the ULN2803 to 6V and each of the other coil wires to an output of the ULN
    I also have a few Shibaura S4H56B06K-06 6V 1.1 A 1.8Degree Stepping motor same thing 6 wire I did the same thing to figure out wiring found common and the associated wires to go with the common making up the coil I took them out of working machines and saw them
    run with my own eyes but I have never been able to build a circuit and get them to step using my Stamps or Props . I am wondering if I am wrong and these are not even unipolar the reason I said they are is from what I found on internet and one place said 6 wire steppers were unipolar I have to ask is there any way I can connect one to a 5 volt power supply and by hand switch the power on and off just to see them step????
    Steve I would love to see your code and how you connected your stepper if you would not mind
    One more thing I have the stepper kit from Parallax its a 5 wire stepper that works with the Basic stamp2 or homework board I have gotten that to work just fine with Parallax code and my OEM Stamp2 however it is 5 wires and no matter how I tried to wire up one of the 6 wire steppers they would not work with this example
    I very much appreciate being able to come here and ask you guys for help and everyone taking the time to try and help
    edited 2009-09-12 01:19
    I'm buffering my motor through an L293D driver chip and using a 12V gel cell for power. The enable pins on the driver are tied to 5V via a 4.7K resistor. My two motor center taps are connected together and hooked to ground. Very straightforward connection setup.
    I can post a schematic if you wish.
    ..Steve
    I'm getting a server error rolleyes.gif when trying to attach the code so here it is...
    {{ StepperTest.spin
    Stepper motor test by Steven R. Stuart   14-Aug-2009
    This program was tested on a 1.8° full step motor, 200 steps/revolution uni-polar stepper motor
    Low power sequence
      Winding X1 100010001000100010001000    X and Y center-tapped winding 1
      Winding Y1 001000100010001000100010
      Winding X2 010001000100010001000100    X and Y center-tapped winding 2
      Winding Y2 000100010001000100010001
                  time --->
    This sequence will generate about 1.4 times torque
      Winding X1 1100110011001100110011001
      Winding Y1 0011001100110011001100110
      Winding X2 0110011001100110011001100
      Winding Y2 1001100110011001100110011
                  time --->
    CON
      _XINFREQ = 5_000_000          'Frequency on XIN pin is 5 MHz
      _CLKMODE = XTAL1 + PLL16X     'System clock = 16x PLL = 80MHz
      pinX1 = 4                     'The pins controlling the motor coils
      pinY1 = 5
      pinX2 = 6
      pinY2 = 7
      speed = 200                   'Higher is faster. 200 = 1 revolution per second
    VAR
      byte seq
    PUB StepperMotor | index
      seq := @SEQ1                                          'Select step sequence: @SEQ1 or @SEQ2
      dira[noparse][[/noparse]pinX1..pinY2]~~                                  'Set stepper pins as output
      repeat  'Run forever
        repeat 50                                            'One full circle (50 steps)
          repeat index from 0 to 3                           'Step thru the four SEQ pattern bytes
            outa[noparse][[/noparse]pinX1..pinY2] := byte[noparse][[/noparse]seq][noparse][[/noparse]index]           'Output a pattern
            waitcnt(clkfreq / speed + cnt)
                                                             'Run SEQ in reverse
        repeat 50
          repeat index from 3 to 0
    DAT
    '                 Y1&#9488;&#9484;X2
    '                X1&#9488;&#9474;&#9474;&#9484;Y2
            SEQ1 byte %1000, %0010, %0100, %0001            'lower power
            SEQ2 byte %1001, %1010, %0110, %0101            'higher torque
    edited 2009-09-16 19:57
    w8an thank you I would like to see your schematic if you take a look at mine you can see I have tied both commons together but them tied them to +12V I am not quite clear how you are supplying power to your steppers if you are tying common to ground?
    I use (or I am trying) to use the ends of the stepper coils to provide the steps Via the prop outputs buffered through the ULN 2803 I am still not having any sucess getting the steppers to do anything more than Buzz
  • JonnyMacJonnyMac Posts: 9,818
    edited 2009-09-16 20:00
    I wrote a really simplistic Spin driver back in 2006 -- this may help you: http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/vol7/col/NV136.pdf
    edited 2009-09-16 21:57
    Hello Mike,
    what frequency are you using ?
    did you try changing the A, A' wires ?
    did you try changing the B, B' wires ?
    steppers often just buzz if one of the wires is connected vice versa than how they should be connected
    if you mount something on the axle of the steppers maybe 10 cm long to see a bigger movement of a single step
    with a step-frequency as low as 1 Hz and you switch just between two bitpattern of the sequence always for and back does the stepper do that ?
    If you add a third bitpattern 1,2,3 and always switch them 1-2-3-2-1-2-3-2-1... does the stepper do that ?
    try experimenting with different bitpattern sequencies
    best regards
    Stefan
    edited 2009-09-16 22:28
    Hey Stefan I was trying to follow JonnyMacs excellent tutorial I have decided to wait until the L293 chips I just ordered come in . This seems to be the chip everyone is using to drive these Unipolar steppers
    I have tried changing the wiring with no luck and I did put a very long wire on the shaft to see if maybe they are moving and I am no seeing it but that is not the case. Great idea though and thank you for it.
    I am hoping the L293 will make the difference if you look at my schematic I am using the common of both stepper coils and driving it at +12 so I really do not have a ground for the stepper coils then I was using the prop outputs to send the steps buffered through the ULN2803
    I can not thank everyone enough for all the help so I will let this rest until parts come in I have in the meantime tried using LEDS as was suggested here and even my quad scope so I can clearly see the code examples are sending pulses out on the right prop pins so it has to be the way I am driving/wiring the steppers as you have suggested.
    edited 2009-09-16 23:29
    Mike, there is no rocket science involved in making a stepper motor work. The L293s aren't magic either but they are half-bridge drivers suitable for bipolar motors whereas all you need for unipolar is an NPN transistor. If you hook up 4 grounded switches to the 4 windings you should be able to sequence them manually.
    A on, B on, A off, C on, B off ...etc
    If that doesn't work then it's your motor that's the problem.
    The 2803s should be working although individual NPNs (with diodes) would be less problematic and deliver the full voltage and current. Take the ZTX849 in a little plastic TO92 style package, it handles up to 5A continuous with a maximum of 0.22V drop and still the gain is around 100 to 200. Of course MOSFETs have an internal diode and can easily handle the current too, but the NPN is a standard through-hole part and very small.
    You don't need a transistor this good and there are plenty to choose from so why bother with special drivers?
    *Peter*
    edited 2009-09-17 01:10
    Thanks Peter but I guess I am still getting confused when you say 4 windings do you mean this because my motors have only 2 coils unipolar 6 wire
    I wish I could draw this better but here goes coil 1,,,,, 1
    middle leg is common
    2 other side of coil so" 1 is Blue" (middle is white and common) and "2 is the other end of this coil red wire" Now the second coil
    1
    2 the other side of this coil " 1 is green first wire"(middle is white common same as other coil) and the other end of the coil wire end is "black"
    So I have 2 coils oh by the way this is the Vexta 2 phase 2610--- each coil is divided in half by the common wire if you look at my schematic I tied both commons to +12 V and either end of the other coils to the outputs of the ULN2803
    To simplify this I will run to Radio Shack tomorrow and pick up a handful of Transistors what do you recommend Pete? Thanks again for all the help
    I have no trouble with servos
    edited 2009-09-17 01:49
    Mike, can you just test the motor with switches to make sure that your connections are correct. If you can't get it to work with switches then you won't be able to get it to work any other way either. Simple test would be to hit a switch, release it and try one of the other ones to find out whether it is adjacent and in which direction.
    I couldn't find the 2610 on the Vexta website. Do you have a link?
    There is a diagram here of your 6 wire unipolar. (The 2 commons are tied together to the supply voltage for your application)
    www.probotix.com/stepper_motors/unipolar_bipolar/
    *Peter*
    edited 2009-09-17 14:47
    ^ You don't even need switches.· I'd try just connecting the commons to the positive voltage source, then grounding the other 4 coil leads one at a time - you only need to touch the lead to the ground because the motor movement should be instant.· You may or may not actually see the pole move (the long wire acting as a dial indicator may help), but you should probably feel the jerk as the pole moves.· Grounding each lead in the proper sequence should cause the pole to rotate.
    It could be you are confusing the leads, you should be able to confirm the coil wiring·using an ohmmeter.· For each side, the pair with the greater value between them are the leads you want to control by switching to ground, and the wire that results in the lessor reading from the other two is the common which should be connected to the positive rail.
    edit - oops, missed your post indicating you have already down this^
    Also, I would slow your frequency down to a crawl in your code (maybe 1 pps) so you can visually observe what is happening.· The 'buzz' is a result of your code changing outputs so quickly.
    Post Edited (Agent420) : 9/17/2009 2:58:19 PM GMT
    edited 2009-09-18 01:18
    Mike,
    here's the datasheet for the L293D buffer/driver: www.datasheetcatalog.org/datasheet/texasinstruments/l293d.pdf.
    I've attached a schematic showing how I connected my motor. I don't know if the motor wire colors are of any standard values, but I included them.
    To view movement, I just placed a 1 inch piece of black electrical tape to the shaft of my stepper.
    Good luck
    464 x 393 - 10K
  • Brian CarpenterBrian Carpenter Posts: 728
    edited 2010-04-27 03:52
    W8an or anyone,
    i have dug up this post because i am a little lost. I have a bipolar stepper. that i would like to use with your code. I am using the PPDB that has the L293 on-board.
    The stepper motor has the following wire colors...orange, white, green, yellow, black, brown, red and blue.
    i have used a continuity tester and determined that the coil pairs are as follows (orange/white), (green, yellow), (black/brown), (red, blue)
    I realize that i need to connect the two opposing coils together making a set of two coils called A and B. So i would have A,*A,B,*B with two sets that are tied together separately. (make sense?)
    How do i know what coils oppose each other and belong in A group and in the B group?
    The PPDB has a terminal block that starts at GND, OUT0, OUT1, OUT2, OUT3, V+
    I have connected a supply voltage of 13.8V to the GND and the V+.
    What wires connect to the remainder terminals?
    Will the code that was supplied above work with this motor?
    Thanks for any help that anyone can render.
    It's Only A Stupid Question If You Have Not Googled It First!!
    edited 2010-04-27 04:15
    coils like this
    nnnnnn
    nnnnnn
    nnnnn
    nnnnn
    A *A,A *A B *B,B *B
    edited 2010-04-27 04:17
    well that didnt look right on the screen
    I will try to find another way to illustrate.
    edited 2010-04-27 04:57
    Brian Carpenter said...
    Do you know the brand name and model number?
    I don't think unipolar code could ever work with a bipolar motor. [noparse][[/noparse]EDIT: oops, I think I'm wrong about that. What I should say is that you can't run a bipolar motor in bipolar mode using unipolar code. Sorry about that.] I've recently been using a chip for controlling bipolar motors, the L6208. If you look at the attached pdf, you'll find it has a diagram of how it switches the voltage inside the chip to energize the coils for bipolar mode.
    Here are some links that help explain a little about different kinds of stepper motor controllers:
    dkc1.digikey.com/us/en/tod/STMicroelectronics/StepperFundamentals_NoAudio/Stepper_Fundamentals_NoAudio.swf
    www.cs.uiowa.edu/~jones/step/physics.html
    I hope that helps a bit,
    Mark
    Post Edited (ElectricAye) : 4/27/2010 1:11:09 PM GMT
  • lardomlardom Posts: 1,659
    edited 2010-04-27 05:19
    Try this. I use a 6 wire and I use·a ULN2803. Let me know how things turn out. As long as you know how to find out which wire is which it should work for you.
