Missing the Propeller
I start a new project tue at work and I'm up late tonight
looking over the details and putting down some ideas about
the code I will have to write. This is the first significant
program I will be doing since I started playing with the
propeller and it's really surprising how limiting it now seems
to have to do everything with a single processor :-(
It used to be kind of fun cramming fast code into interrupt
routines and getting it all to work.... playing with 8 cogs
on the prop has really made all of that seem like old tech.
I wish there was a way I could make a prop work in the new
project but since I am the only one here who has experience
with it there is no way to get them to use it...it also really has
too little mem and speed for this. I sure wish the prop2 was
out already... I'd be willing to do all the coding myself just to use
a chip with multiple cogs. When the prop2 becomes available
I am going to try and get them to use it in most projects... I
think I have a good chance, especially if I can show off the prop2
running fast compiled C code. I hope that a good C compiler for
the prop2 is available as soon as the chip is.
I'm really going to miss the Prop for the next month or so as I code
this new project.... I just won't have any time or energy left over to
even play with the prop at home.
This is just really going to suck :-(
"Where am I? Where am I going? Why am I in a handbasket?"
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
But even with an rtos it still is not even close to the same as having lots of cogs.
It's just a whole new mindset once you get into using multiple processors.
And once you experience the benefits you hate to go back.
Usually I do the code inside interrupt routines in asm
so I can do more stuff in the limited amount of time avail.
It is amazing how much you can do in 0.0001/sec
if you have to. But having a whole cog to do it would be
a lot easier and more fun.
Post Edited (HollyMinkowski) : 9/8/2009 9:06:17 AM GMT
Leon
