:hop: Smart Card incorporating 1KByte of EEPROM
Smart Card - SLE4428
Standard ISO-7816 Smart Card incorporating 1KByte of EEPROM storage and a Programmable Security Code, Standard Byte Addressing, with three wire serial bus. Suitable for 10,000 write and erase cycles together with data retention of ten years. Ideal for parking, stored value or access control systems.
Features
• Standard ISO-7816
• Long-Life Contact Material
• 1KByte EEPROM with Programmable Security Code
• Ideal for Sensitive Data and Security Systems
Above is a card I found $1.50 AUS and a socket holder for a few bucks. Can I hook up a stamp or propellor to the socket and access the EEPROM for read and write , using umm..... I2C or some other protocol ?
Features
• Standard ISO-7816
·········· Mike L.
You will need some kind of buffer between a Propeller and this chip since this is designed to run off 5V and the Propeller is a 3.3V chip. There's a long thread among the "sticky" threads at the top of the thread list on the Propeller forum that deals with interfacing a Propeller with 5V logic.
