Hobbico cs-80. Does it work with BS board?
I am creating a project to turn a door knob. I need quite a lot of torque and the 150 oz/in barely pulls it. Would the Hobbico cs-80 work with the BS2 module and the BOE board, on a 9vdc 300ma power supply? Or will i need some sort of external power/ upgrade to a 12v power supply? Here is the link to the servo: www3.towerhobbies.com/cgi-bin/WTI0001P?I=LXLN93&P=8 Thank you
I suggest you browse some servo manufacturer's catalogs and see what sort of current drains are typical for 300+ oz/in servos.
The servo it uses draws 150ma (no load).
You still need a separate power supply like Mike says. Servos aren't designed to run on more than 6 volts, especially when loaded.
Rich H
The Servo Boss, a 12 channel servo tester kit from Gadget Gangster.
