Can I do this with one cog? (solenoid control with current feedback) — Parallax Forums
IntrepidIntrepid Posts: 6
edited 2009-09-08 07:23 in Propeller 1
I need to drive a solenoid via PWM ( using a peak and hold methodology) controlling the duty cycle based on a single channel ADC monitoring a current sense resistor. The ADC communicates via SPI. Can this be done with 1 cog?
John
    edited 2009-09-07 02:04
    Yes, I'm sure it can. But first, what do you need for the PWM frequency? If necessary, could you spare two pins for the PWM and provide an external XOR gate?
  • IntrepidIntrepid Posts: 6
    edited 2009-09-07 03:22
    Phil,
    The PWM frequency is dependent on the inductance of the solenoid for now let's assume 1 KHz - 10 KHz. I am not very familiar with the propeller architecture at this point, what is the reasoning behind the external XOR? I am hoping to control 6 solenoids in this manner and interface the propeller to a DSP so it may be difficult to spare 2 pins for each channel as that would be 5 pins per channel (3 for SPI and 2 for PWM) not leaving enough for the DSP to talk SPI to the prop. I am trying to decide between the propeller and a small FPGA.
    John
    edited 2009-09-07 03:34
    Okay, now I understand it better. You hadn't stated that you needed six PWM outputs, and I was trying to figure out how to do everything just from Spin. The XOR would have been to convert two counter outputs to a single PWM. But with six outputs, that all changes.
    This is for fuel injection, right? You could have one cog doing the PWMing for all six solenoids. Another could handle the ADC(s) and compute the necessary PWM outputs. What is the DSP doing? Are you sure that can't be handled by the Prop, as well?
    edited 2009-09-07 03:46
    It is not for fuel injection. I have an industrial application that uses a number of solenoid modules. The DSP is a current component of the system and does a number of high speed floating point calculations for feedback control of various processes. For legacy reasons, the DSP will not be replaced. I was trying to encapsulate all of the functionality for a given channel in a single cog but I think your configuration makes more sense. I will investigate further, thanks!
  • hinvhinv Posts: 1,272
    edited 2009-09-07 04:52
    Hi Phil,
    I think I am missing something. Why would you need to use 2 counters and an XOR? Would't one counter per solenoid work just fine?
    Doug
    edited 2009-09-07 17:35
    Doug,
    The DUTY mode output from a counter is too fast to switch a solenoid driver efficiently. To do that you need PWM instead. But PWMing can't be done autonomously with a single counter. It needs a software assist from the Prop, which is pretty much a full-time occupation. (An 8-bit PWM at 10KHz requires a timing granularity of less than 8 assembly instructions.) The OP stated that he wanted the PWM and SPI in one cog. While not impossible, the code would be a bit opaque, since servicing PWM and SPI would have to be interleaved. But by using two counters and XORing their outputs, you can get a PWM output whose duty cycle can be varied from 0 to 100% just by varying the counters' relative phase. This continues without further program assistance (until a different duty cycle is called for), thus freeing the cog for reading the ADC in a simple and timely fashion.
    But when the OP said he had six solenoids, that changed the whole scenario, since one cog can just as easily drive six solenoids using software as it can one using an object from the OBEX.
    edited 2009-09-08 04:22
    Hi Phil,
    Are you saying that in duty mode the frequency is too high so at a FRQ of 2147483648 would give you a 50% duty cycle, but the output frequency is still 80MHz?
    What kind of frequency do you need for a solenoid? I would guess you would want something above 20KHz to keep it out of audible range.
    So the solution you are suggesting is using 1 main cog for spin, 6 cogs for SPI, and one COG for 6 interleaved PWMs?
    Doug
    Doug,
    At 50%, the duty mode output would be 40MHz; at 25%, 20MHz. This is way too fast to drive a solenoid driver. It would spend most of the time in its linear region and overheat. The optimum PWM frequency is dependent on the solenoid's inductance and switching characteristifcs of the driver circuitry. Audibility is a secondary concern — especially if the solenoids are out of earshot or in an already noisy environment.
    You probably would not need six cogs for the SPI. In fact, if they shared common clock, /CS, and Din lines, one cog could probably handle it.
