Quantum silicon chip
Some Brits have reduced the table full of equipment needed to work
with entangled photons down to an optical silicon chip.... this is just too cool!
www.newscientist.com/article/dn17736-codebreaking-quantum-algorithm-run-on-a-silicon-chip.html
Public key algos may not have much life left in them.
We seem to be close to the ability to factor very large numbers with
these sorts of optical chips.
- Some mornings I wake up cranky.....but usually I just let him sleep -
Dave
www.idquantique.com/
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
Problem is, that as is always the case, in short order, there will be a counter technology that will come along and find a way to decrypt the new system... Always a one-step-ahead/behind sort of thing.
Dave
Dave
However if done correctly OTP is uncrackable. the difficulty is in doing it correctly. You need a long true random key and you must always deliver this key by physical means.
It is strange how the most sympolist of encryption methods is the safest.
How to do OTP:
1) Generate extremely long truely random key
2) deliver key to recipient by trusted courier.
3) xor your message with the key.
4) discard bits of key that you used.
5) transmit encrypted message to recipient using any unsafe method.
6) recipient xor encrypted method with key to get original message.
7) recipient discards used bits.
the beauty of this is any message could mean anything. even if the encrypted message came to
"jump off a bridge"
which would be unlikely but possible. the unencrypted message could be anything. most of the time the encrypted message will look like gibberish though occasionally it does look like an actual sentence. The only way it can be cracked is if the key is not truely random, you reuse parts of key, or the curiour is compromised.
