I must be jinxed
I got my USB Propeller Education·kit today. I installed the USB driver as per the web link, then plugged my Propeller Plug in, the tiny red and blue LEDs flash,·and.... nothing happened! I tried all the USB ports, and even tried 2 other computers! Nothing·on any of them!
I send an email to support...
Then opened up my USB Boe-Bot and got the same thing!
Obviously, unless there is a bad batch of FTDI chips, it must be me, so here's what I have for systems and what I've done.
I followed both kits as per the instruction manuals.
I've uninstalled ALL the Parallax software and reinstalled.
I've checked my USB ports to make sure they are setup for 'legacy'.
My systems are a Pentium 4 with XP SP3, an I7 with Vista 64, (also has Windows 7) and a Core 2 Duo laptop with Vista 64.
Every computer/OS has the same symptoms! LEDs flash, then no action!
So, what am I doing wrong?
Tom Lewis
Tom Lewis
There is not much that will happen when you plug in the Prop plug, until you try to use it to communicate with the Propeller chip via the Propeller Tool software.
Not sure how you can use the Boe-bot to test the Prop plug... maybe you have a bad cord.
Rich H
The Servo Boss, a 12 channel servo tester kit from Gadget Gangster.
With the Boe-Bot, I only need to plug in the Basic Stamp, then the USB cable (LEDs flash), plug in battery pack, slide switch to position 1, (green LED glows). Test communications with BASIC Stamp Editor -> Run -> Identify. (No port found.)
Also, when I go to Device Manager, no Ports (COM & LPT) displayed.
Good deal! Think I'll do the same.
Rich H
