Cog Memory Dump?
grahamreitz
Is there a method to dump the contents of a cog's memory? I am working in pasm. It doesn't need to be real time. All that is necessary is to dump the contents once a pasm program has completed.
I apologize if this has been answered before. I entered 'cog,memory,dump' (no quotes) and received no results. Although, I found a post by cluso that had exactly that phrase. It only seems to work if I enter only one search item.
graham
graham
There's no way to access the cog's memory from another cog, so any dump scheme has to be made part of the program running in the cog. The easiest way to do this would be to just add a loop to the end of your program to copy the contents of the cog to a 2K buffer in the hub. You can then dump it from the hub buffer any way you want.
dumpLoop wrlong dumpDest,0 ' Write 4 bytes to the end of the hub add dumpLoop,#1 ' Increment the source add dumpDest,#4 ' Increment the destination djnz dumpCount,#dumpLoop ' Repeat for 512 longs cogid dumpTemp ' Now stop the cog cogstop dumpTemp dumpDest long $8000 - $800 dumpCount long $200 dumpTemp long 0Post Edited (Mike Green) : 9/5/2009 12:55:59 AM GMT
You could also try my BMA debugger which has a dump feature and other things. It is pure Spin/PASM.
--Steve
Propeller Tools
