how to repeat while one of n statements is true — Parallax Forums
youngdaveyoungdave Posts: 70
edited 2009-09-04 23:16 in Propeller 1
Dear All
Is the following type of thing possible in Spin?
repeat while diff_x > previous_diff_x
repeat while diff_y > previous_diff_y
or maybe
repeat while diff_x > previous_diff_x or diff_y > previous_diff_y
TIA David Young
  • JonnyMacJonnyMac Posts: 9,850
    edited 2009-09-04 23:06
    Had you typed that code into the Propeller Tool instead of the forums, you could have pressed F8 and found the answer to be "Yes." tongue.gif
    Of course, withing the repeat while structure you need to update the variables being used in the condition so that you can break free of the loop. You may want to add parenthesis to make your intentions absolutely clear:
    repeat while (x > lastx) or (y > lasty)
    Post Edited (JonnyMac) : 9/4/2009 11:16:26 PM GMT
    is perfectly acceptable
