RamBladeProp with SRAM to run CPM & ZiCog plus other LMM software (SMT pcb)
Cluso99
I have had a number of designs that have not come to fruition for one reason or another... Too much time to re-think options.
RamBlade·is a small fully smt version pcb about 1"x1.8" and·designed to·plug into·a Prop ProtoBoard (or similar) which will be used to download the code to the RamBlade and then act as a Terminal and I/O to the RamBlade.
RamBlade is designed to run...
RamBlade specifications are... (Block diagram attached) (differs from that previously published here)
Comments please?
· Home of the MultiBladeProps: TriBlade,·RamBlade, RetroBlade,·TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
· Search the Propeller forums·(uses advanced Google search)
Post Edited (Cluso99) : 9/4/2009 12:44:18 PM GMT
- CPM2.2, CPM3 & ZiCog
- MoCog & Flex when complete
- PropDos
- Catalina C
- LMM programs
- Designed to connect to another prop board (ProtoBoard, etc) with I/O such as VGA, TV, Keyboard, Mouse, etc
- Boot code to be downloaded by the other prop board (no eeprom on pcb)
- Propeller + xtal (hopefully 120MHz operation)
- NO eeprom (must be loaded by another prop)
- SRAM 512KB (fast - no latches)
- microSD socket (currently accepts up to 2GB)
- External interface (to another prop e.g. ProtoBoard) as follows...
- 3 pin PropPlug style interface to load prop/eeprom (SI, SO & -RST)
- 2 pin serial interface for communication while running (seperate to the above which must be tristated)
- power input 5-9VDC & Gnd
- onboard 3V3 regulation
- Will be available fully assembled
Comments please?
bmp
102K
· Home of the MultiBladeProps: TriBladeProp, RamBlade, TwinBlade,·SixBlade, website
Now to swipe the qwerty keyboard off my imate phone
