RetroBladeProp with SRAM to run CPM & ZiCog plus other LMM software (T/hole pcb)
Cluso99
I have had a number of designs that have not come to fruition for one reason or another... Too much time to re-think options.
Here is my latest for your comments. Basically it is a through hole design (yes I know the DIP prop is hard to get, but that will hopefully be solved soon).
RetroBlade is designed to run...
RetroBlade·specification... (Block diagram attached)
Comments please?
· Home of the MultiBladeProps: TriBlade,·RamBlade, RetroBlade,·TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
· Search the Propeller forums·(uses advanced Google search)
Post Edited (Cluso99) : 9/4/2009 12:43:17 PM GMT
- CPM2.2, CPM3 & ZiCog
- MoCog & Flex when complete
- PropDos
- Catalina C
- LMM programs
- Can run standalone or connect to another prop board with I/O such as VGA, TV, Keyboard, Mouse, etc
- Propeller + xtal (hopefully to run at >100MHz)
- EEPROM 32KB/64KB/128KB
- SRAM 128KB or 512KB (fast - no latches)
- microSD socket (currently accepts up to 2GB) smt but hand solderable
- Capable of SBC (single board computer) operation
- Alternate options for serial connection (only one option)
- Keyboard PS2 interface via either PS2 or USB-A connector
- PropPlug 4-pin header via external PropPlug (not supplied)
- TTL 3V3 serial interface (2 wire)
- RS232 serial interface (2 wire)
- Note, transistor reset circuit can be mounted on the pcb so the RS232/TTL can reset and download the prop/eeprom
- Can connect via PropPlug header to another propeller (like on the TriBlade) for Terminal and additional I/O
- Alternate options for display
- None (all 512KB SRAM available)
- 1-pin TV (only 256KB SRAM available)
- 2-pin TV (only 128KB SRAM available)
- 3-pin TV (only 64KB SRAM available)
- 1-pin TV & mono audio (only 128KB SRAM available)
- 2-pin TV & mono audio (only 64KB SRAM available)
- 1-pin TV & stereo audio (only 64KB SRAM available)
- Anticipated to fit into Hammond 1593L enclosure (2.6"x3.6")
Comments please?
bmp
102K
· Home of the MultiBladeProps: TriBladeProp, RamBlade, TwinBlade,·SixBlade, website
Cheers!
Paul Rowntree
Secondly, if you are not using the keyboard or RS232 option, there is no need for the 5V regulator to be fitted.
Looking forward to being able to get a couple of these new boards. Having great fun with TriBlade and following the CPM saga!
TrapperBob
