6 Degree of Freedom, anybody?(Accelerometer/Gyroscope board)
I just got on the Mouser.com homepage to look up something totally unrelated, when I saw this. I've kept up a little bit with the new produts various companies are coming out with, but I had forgetten about ST Microelectronics' gyro's. They had announced them many moons ago, but the products wouldn't be for sale until this summer. I gotta say - Wow. A dual axis gyro for $6.72(mouser pricing). They make these in various sensitivities, and also 3 different axis orientations(only 2 axis per chip). ST Also makes some really nice accelerometer chips, too.
I'd like to get some of these for·my (someday) quadrocopter project. These chips are a pretty hard-to-solder surface mount part, so I think I'm going to get a few boards professionally made, rather than do my home-brew single sided boards. I'm just curious if anyone else would be interested in one of these.
What I had in mind, was a board consisting of a tri-axis accelerometer, a couple of gyroscopes, and an ADC. The ADC I have in mind is a TLV2543(12-bit, 11channel, 66ksps). The accelerometer and gyro have analog outputs, so the ADC would read these. With this setup, the accel/gyro would eat up 6 ADC inputs, but the board would have 5 extra inputs for various external·uses. The whole interface would use 5 I/O pins. There is an object in the OBEX for the Propeller for the ADC(written by the fantastic Timmoore).
However, I would request that the chip ADC outputs are broken out, or, if there isn't enough room, then pads are provided so that we can solder on wires. Also, a DIP format would be very nice.
James
Post Edited (Philldapill) : 9/3/2009 2:01:32 PM GMT
store.diydrones.com/ProductDetails.asp?ProductCode=BR-0006-10
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
Its currently being tested with 2x IDG300, 1 ADXL330 and 1 CMPS03 with a tlv2543 but the object doesn't contain the A2D it runs outside the object. So I run 1 cog for the A2D and 1 cog for the IMU. The A2D object needs to output its values in a hub array that you also config into the imu object. This allows the A2D to be used for other analog inputs as well. The imu object also takes the gyro gains and other hardware config during initialization so it should work with most gyro/acc/compass.
I will post the code as soon as I have finished testing the new version. I also have the new sparkfun diydones imu and will be testing on that with a hmc5843 compass.
If you are building a imu I suggest you look at the hmc5843 compass and include that. A compass is needed for the 6th axis to stablize the gyro.
PS It you want to cut the cost of the sparkfun diydrone at the cost of a bit more work. You can use sparkfun for the main board and pololu gyro (its the same gyro) for the add on boards. The extra is the 3.3V and Gnd are switched in the pololu board so assembling it is harder but it addon boards are cheaper.
PPS. If you are thinking about the tlv2543 take a look at the tlv2556, its the same with a few extra options but also can be run faster. The current object is slowed down to the tlv2543 speed, with the tlv2556 it should be able to be run faster but the current code should run as is.
Post Edited (Timmoore) : 9/3/2009 3:57:42 PM GMT
Any updates on your code?
Bill
Kneel before Zod! We will crush the son of our Jailer!
@erco, take a look at the itg3200 - triaxis gyro for $15
