MLX90614 - Bad Unit?
So I just got my latest package from Parallax, and the MLX90614 unit I purchases is kicking out PEC "Fails". . .I can't get anything out of this unit. I dropped in a 10 degree unit I have lying around and it works perfectly. . .drop in this new one. . ."Fail". Any suggestions before I arrange a replacement with Parallax? I actually had the same problem with the first one I bought when it was right out of the box, and it quite magically started working the next day. This is all so confusing [noparse]:([/noparse]
-Jeff
-Jeff
There are lots of posts of people, who ran the simple program first. But this reqests data from $5A whereas the MLX90614 is factory set for $35, though apparently it will also read from $00.
Everybody is frustrated by this. In reality, the "set eeprom" prigram should have not confused everybody by changing this location, and the simple program should read from the factory-set location.
Worth trying again? Let us know if this does the job.
Regards
Rupert.
Please let Technical Support know [noparse][[/noparse] support@parallx.com or 888-997-8267 ] if you have a module that you may think is defective, and we can set up an RMA to test it. However, Ruperthart has a good suggestion; if you do not set the address they will not run properly; all the sample code uses $5A as the desired address to communicate with.
Respectfully,
Joshua Donelson
www.parallax.com
