Program: SW21-EX14-Debounce.BS2 Here is how you use each button by it self us
[font=Tahoma,Bold size=2][font=Tahoma,Bold size=2]I do not have time to night to run this routine and play with now
·[/font][/font]' {$STAMP BS2}
' {$PBASIC 2.5}
[noparse][[/noparse] Program Description ]
' This program demonstrates the simultaneous debouncing of multiple inputs.
' The input subroutine is easily adjusted to handle any number of inputs.
[noparse][[/noparse] I/O Definitions ]
BtnBus VAR INA ' four inputs, pins 0 - 3
[noparse][[/noparse] Variables ]
btns VAR Nib ' debounced inputs
idx VAR Nib ' loop counter
[noparse][[/noparse] Program Code ]
Main:
DO
GOSUB Get_Buttons ' get debounced inputs
DEBUG HOME,
"Inputs = ", IBIN4 btns ' display in binary mode
PAUSE 50
LOOP
[noparse][[/noparse] Subroutines ]
Get_Buttons:
btns = %1111 ' enable all four inputs
FOR idx = 1 TO 5
btns = btns & ~BtnBus ' test inputs
PAUSE 5 ' delay between tests
NEXT
RETURN
··Thanks for any·
·that you may have and all of your time finding them
Sam
Post Edited (sam_sam_sam) : 9/5/2009 4:44:39 PM GMT
' {$PBASIC 2.5}
Main:
DO
DEBUG HOME,
PAUSE 50
LOOP
Get_Buttons:
FOR idx = 1 TO 5
NEXT
RETURN
··Thanks for any·
Sam
This is a good Question that I have wondered about for a few years.
I was never brave enough to ask it !
___________$WMc%_________
The Truth is out there············································ BoogerWoods, FL. USA
'·· File...... SW21-EX14-Debounce.BS2
'·· Purpose... SCANNING AND DEBOUNCING MULTIPLE INPUTS
'·· Author.... Parallax Stamp Works EXPERIMENT #14
'·· E-mail....
'·· Started...
'·· Updated...
'·· {$STAMP BS2}
'·· {$PBASIC 2.5}
[noparse][[/noparse] Revision History ]
BtnBus······· VAR········· INB·········· ' four inputs,··· pins 4 - 8
Led·········· VAR········· OUTA········· ' four outputs,· pins 0 - 3
[noparse][[/noparse] Constants ]
btns····· VAR······ Nib··········· ' debounced inputs
idx······ VAR······ Nib··········· ' loop counter
[noparse][[/noparse] EEPROM Data ]
[noparse][[/noparse] Initialization ]
DIRS = %1111111100001111·········· ' This is a must or this will not work
Main:
DO
GOSUB Get_Buttons············· ' get debounced inputs
IF btns = %0001 THEN·········· ' You can not use HIGH OR LOW command it has to be done with BIT 0 or 1
led = %0001·························' This turns ON your LED Light········
ENDIF·································
DEBUG HOME,
"Inputs = ", IBIN4 btns······· ' display in binary mode
PAUSE 5
LOOP
Get_Buttons:
FOR idx = 1 TO 5
NEXT
led = %0000················ ' This turns OFF the LED Light
RETURN
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 9/5/2009 6:48:40 PM GMT
'·· File...... SW21-EX14-De-bounce Part 2.BS2
'·· Purpose... SCANNING AND DE-BOUNCING MULTIPLE INPUTS
'·· E-mail....
'·· Started...
'·· Updated...
'·· {$STAMP BS2}
'·· {$PBASIC 2.5}
BtnBus······· VAR········· INB·········· ' four inputs, pins 4 - 8
xbtns····· VAR······ Nib
nbtns····· VAR······ Nib··········· ' debounced inputs
idx······· VAR······ Nib··········· ' loop counter
oBtns····· VAR······ Nib
Main:
DO
DEBUG HOME,
"Inputs = ", IBIN4 xbtns······· ' display in binary mode
PAUSE 5
IF xBtns = %0001 THEN····· ' This stay TRUE for one seconds then go False this is the only different from the one above
HIGH 0
ELSE
IF xBtns = %0000 THEN
LOW 0
ENDIF
ENDIF
LOOP
·Get_Buttons:
nBtns = %1111 ' enable all four inputs
FOR idx = 1 TO 5
nBtns = nBtns & ~BtnBus ' test new inputs
PAUSE 50 ' delay between tests
NEXT
xBtns = nBtns ^ oBtns & nBtns ' look for 0 -> 1 changes····· This is different from the one above
oBtns = nBtns ' save this scan
RETURN
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 9/5/2009 4:49:46 PM GMT
There was a two·little bug in this routine code it has been fix
·SCANNING AND DEBOUNCING MULTIPLE INPUT.BS2
I will have a use for this routine when I to scan 4 input and if more than one input go high then do some routine
I have just got a PDB a week ago and thought I would try this routine out·· SCANNING AND DEBOUNCING MULTIPLE INPUTS
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 9/5/2009 10:07:17 PM GMT
IF Btns = %0001 THEN ' Here is the answer to this question that I ask earlier How ever if you do this Btns = %0101 THEN both button
HIGH 0 ' need to be pushed at the same time for the statement to be TRUE
ELSE
Wonder if anyone else thought Matrix Keypad Decoder at this point?
Strange that the section above disappears when trying to quote the post it was in, so i just copied and pasted the paragraph,
possible forum bug?
possible forum bug?
There was a little bug in this routine code it has been fix
I was editing my post at that time and you have not lost it
The problem with what I had posted first was that if you pushed two button one and· another button the led would stay on and that was·not what I was looking for with what is posted now if you try pushing two buttons at the same time the led goes·OFF or dose not come·ON at all
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 9/5/2009 8:59:55 PM GMT
I think that if you used the SCANNING AND DEBOUNCING MULTIPLE INPUT·4 TO 8·*.BS2 that
I posted that should work for this Matrix Keypad Decoder
Because in that code routine the Led stay·ON for one second and then goes OFF when the right button is pushed
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 9/5/2009 10:21:10 PM GMT
I think the Button/Btns command is worthless, It needs to much code to make it work.
Just My thoughts
________$WMc%____________
This routine is really good if you need to compare more than one input to another other wise I have to agree with on that it take a lot of coding
other wide to do one input
The time that I send learning how to do·it was well worth the time I·spend doing because
I was going do a Project that would entail compare two inputs and would take a lot of coding
to make sure that both input are 1 before the routine would start and would exit the routine if one or the other input· was 0 this would be need
for safety reasons
··Thanks for any·
Sam
Here is what I have cobbled together.
It can monitor all 16 inputs if necessary.
It detects positive going pulse - from 0 to 1.
It can be modified for negative pulses.
It has programmable debounce timer - in 1 ms increments.
Basically a change detect loop followed by a delay loop.
Just keep in mind that we are trying to filter out erroneous pulses in 5 to 30 ms range.
So the overall delay should reflect that.
' {$STAMP BS2e}
' {$PBASIC 2.5}
counter VAR Word
debounce VAR Word
testVariable VAR Word
debounce = 20
Main:
testvariable = 1
DO
· DO
··· DEBUG BIN16 ? testvariable
· LOOP UNTIL (testvariable > 0)
· DEBUG "Input detected - high",CR
· ' debounce delay
· DO
··· counter = counter + 1
··· PAUSE 1
··· DEBUG ? counter, CR
··· PAUSE 200···· ' test delay
··· IF· ((counter = debounce) AND testvariable > 0) THEN
····· DEBUG "process subroutine",CR
····· GOSUB sub
··· ELSEIF (testvariable = 0) THEN
····· counter = 0 ' ready for next one
····· DEBUG "return to Main",CR
····· GOTO Main
··· ENDIF
· LOOP
· testVariable = testVariable + 1
LOOP
sub:
· DEBUG "subroutine",CR
· END
Thank You for sharing you code routine I will give it a try
I am sure there are many ways to accomplish button·DE·bouncing.
I do not always use· (switch buttons to compare inputs) so I·do not alway need to·DE bouncing the inputs
So I was looking at making·a routine that could be used for both type of inputs switches and just power to the inputs
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 9/7/2009 1:49:43 AM GMT
