Video / Internet module
I spent some quality time with DipTrace this weekend and put together an ethernet / video module for the Propeller Platform. It has an ethernet connector / 28j60 controller, a piezo speaker (LS1), and a red LED.
I'm not sure if I'm going to build it, but I've got some extra space on the board. I could fit an SD card slot, or maybe some prototyping space or a few other things. Any thoughts on what I should add (or should I just keep the board comfortably spaced)?
The schematic and PCB design are attached - what do you think?
Gadget Gangster - Share your Electronic Projects
If you have room left I would suggest you add a VGA connector.
Just my $0.02
Brandon C.
No purchase necessary. See back panel for more details.
Tired of the same old robot brains? not enough processing power? Get the Propeller Robot Module now!!
OBC
New to the Propeller?
Perhaps it's just me, but I value the vga capabilties more than ntsc.·· vga offers better resolution allowing more options, and lcds have been around long enough to become available dirt cheap.· I understand that for physically smaller sized projects ntsc works well, but when the size of a std monitor is not an issue, vga wins; it's also viewable from a further distance.
i'm building a couple of wall mounted pong / space invaders clocks and some other terminal based projects...· Eventually I'll work my way up to networked wall mount projects.
I'm a fellow DipTrace user and I just wanted to say your design looks nice and clean. Which method did you use to get the GG logo on the PCB? I have done mine a couple ways, but never end up with results as clean as yours.
I would agree that VGA would be useful as Agent420 mentioned, I use VGA more than Composite because I have LCDs all over the place and can buy a 17" like-new-used one for about $40. Also, most of my "panel only" style projects are done with a VGA driver board and flat panel. One project used a CF media player connected to a VGA driver board for a 10" LCD panel. It plays 8 different MPEG videos off the CF depending on which button you press on a membrane keypad. (the firmware for the CF media board was modified so that it plays 000.mpg in a continuous loop until a button is pressed. When a button is pressed, button 1 plays 001.mpg, 2 plays 002.mpg, etc) It was for a store display that had videos for the various items in a product line.
Andrew Williams
WBA Consulting
WBA-TH1M Sensirion SHT11 Module
- Some mornings I wake up cranky.....but usually I just let him sleep -
Brandon C.
Rich H
The Servo Boss, a 12 channel servo tester kit from Gadget Gangster.
I'm glad to hear there are a few other diptrace fans out there. It took me about a day and a half to figure out how to use it, but I find it much easier than eagle. Using the copper pour was a little confusing, but I've got it now. I've been meaning to write a review on it sometime.
@W9gfo - You could probably use any 3 pins, but the TV driver just requires that they're sequential. I connected the ethernet / tv while keeping in mind how other modules use each pin. So the LED goes at P16, which is where the bi-color LED for the LCD UI module goes.
@holly - yeah, ntsc is last century, but so is VGA. Personally, I just use the TV to do debugging (when I have the memory), but I'm hoping people can come up with some cool audio / visual based projects. Maybe a second audio connector would make sense...
· Propeller Object Exchange (last Publications / Updates)
Rich H
Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
Safety Tip: Life is as good as YOU think it is!
What card are you using for video capture?
I tried one of my O2s video inputs, but it didn't like the propellers output of AiGeneric. It might have been the specific O2 I was trying, so I will have to test my hardware with another video source.
