Ultimate Guide to Inkjet Direct PCB Printing — Parallax Forums
fullspecengfullspeceng Posts: 76
edited 2009-10-29 17:28 in General Discussion
The next Parallax Propeller is supposed to come in SMD only and soldering through hole devices is so yesterday. However, making a PCB board fast and cheap isn't that easy. Making a Homebrew PCB has many advantages such as instant gratification and low cost. There are many different techniques but the fastest/easiest/cheapest way is to use an inkjet printer capable of directly printing on CDs and use an etch resistant ink. You can find answers if you are looking for bits and pieces and willing to try a few things out but until now it has been the EE experimenter's best kept secret.
However, I made it easier and made an idiot-proof step by step guide along with a kit for those that just want to get started and make PCBs quickly and easy without doing any hacking or major modifications. I also made several innovations and improvements such as a special laser cut stencil and finding the best possible ink after many different trial and error tests.
Yes there are limitations and sacrifices but I don't claim this is the only way nor do I claim it is the best way but rather a way that works for sure and easy to follow.
I have written this guide to provide 100% reproducible results. I cover everything from how to prepare the circuit board, how to save the image, how long to bake the board at what temperature to dry it and how long to etch the board in great detail. Follow these instructions and you can have a board in a matter of minutes.
Check out the tutorial www.fullspectrumengineering.com/tutorial.html
Check out the kit www.fullspectrumengineering.com/pcbinkjet.html
Making Homebrew PCBs has never been easier.
    edited 2009-09-02 17:58
    very cool but unfortunetly will not do the tolerances I work with.
    8mil via, 4mil trace width, 4mil spacing
    nor will it do more then 2 layers.
    propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
    Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
    Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
  • fullspecengfullspeceng Posts: 76
    edited 2009-09-02 18:02
    I've heard of people do 4/4 and I've personally done 6/6 but if you *need* results that good, it's better to pay the money to get the board professionally made. Vias and no soldermask are still pains.
    edited 2009-09-02 18:15
    solder masks are a must for me. Would love to be able to prototype in shop but just not feasible.
    my newest product under development(super prop) is 6 layers, via depths of 2..6 and 1..6, i can just barely get everything in.
    edited 2009-09-02 18:38
    I personally like to prototype my board in shop to verify connections and make sure everything works but if you are good with the simulation program then maybe it's not necessary.
    You can always get the form factor later.
    You have some awesome form factor boards but those are WAY outside any homebrew pcb capabilities. That's why they buy from you - it's way cheaper than making your own [noparse]:)[/noparse]
    On a side note, I have an inkjet printable solder mask product coming out soon. It's UV curable ink and superior but I need to run more tests to make sure it doesn't clog up.
    edited 2009-09-02 18:45
    now that is cool. i may look into this for some of my home projects where i can get away with 8/8 clearance and only 2 sided. pcb fab houses aren't to bad in cost if buying by the hundreds but 1 offs for a toy is crazy expensive.
  • TubularTubular Posts: 4,745
    edited 2009-09-02 21:22
    FSE thats a great tutorial, well done.
    The printable solder mask would be a huge leap forward. Even if it clogs after a 'session' it would still be very useful. You could obviously print the overlay as well using that technique.· An ultrasonic cleaner might help unclog.
    Combined with inkjet printable conductive polymers you could then also do multi layer circuits with as many layers as required. That area is really heating up at the moment. I'm collecting conductive polymers and metal laden suspensions waiting for the inkjet side to be possible.
    edited 2009-09-03 03:17
    I'm actually working in the longer run on a project to dispense a lot of various fluids, including solvents.
    Actually I have a parallax propeller ejecting ink out of a Xaar 128 inkjet head which can also do solvents.· We have some great products for XYZ gantrys built to make a 2d xy or 3d·printer.
    The problem with the Xaar is it is $400 just for the head.
    Hopefully we can sell a few of the Epson parts to keep the research going.· Materials are quite expensive when you play with state of the art chemicals.
    The overlay printing is no problem right now with the current pcb resist ink.· It won't wash off.· It's yellow which is pretty close to white.
    I don't think an overlay is very important to a DIY board.· It looks nicer but you can always just a print a copy of your design.· I don't even pay for overlays unless it's a product I'm going to ship to someone else.
    If you want to try the printable soldermask, I can sign you up for the beta test.· The ink will be in the $100-120 range per cartridge (but good for several hundred boards) once it is finished as it is super expensive but I will give it to you greatly subsidized for your comments.· You need a strong UV light source to cure it.· Sourcing something cheap is something else I am working on.· Right now I have a huge mercury lamp and it cures in under 10 seconds.
    edited 2009-09-03 04:58
    i guess i will not sell my uv lamp for developing circuit boards after all. if you potential could come up with something for under $2000 that would let me rapid prototype multilayer boards even if it costs me $50 a board would be well worth it.
    I would still get fab house to make production runs but would save a lot of time if i could build prototypes here. my bigest problem is needing very tight tolerances.
  • mikestefoymikestefoy Posts: 84
    edited 2009-09-03 07:00
    I like the idea of making small, simple boards at home.
    Question.....
    is it impossible to do the process the way it should be done.
    conductive ink on a plain fr4 or equivalent, rather than the "reverse" process of removing the electrical conduction which is not required.
    edited 2009-09-03 07:13
    If you can find conductive ink then I guess that would work but copper is pretty low conductivity. Good luck finding something that matches the copper resistance that comes in a liquid form and getting it to stick on the fr4 forever.
    You can probably mix carbon black with the UV curable ink to form a conductive trace but that's not going to be anywhere as good as copper. I know they have silver conductive solvent based ink in those pens so that might work but it's a lot of experimentation and it gets expensive because you need to buy a new printer if you destroy the head.
    Also a properly designed PCB board has a GND plane on the top and bottom so it is mostly copper. I do like the additive process as you can skip the etching process but the etching process is pretty easy as I have shown in the tutorial. Just get a ziplock bag and throw in some ammonium persulfate and some hot water. 25 mins later you have a pcb and throw out the ziplock bag.
    As I mentioned I have some good experimentation going with the Xaar heads controlled with a parallax propeller so maybe in the future but we need to pay for development costs somehow so hopefully there is interest in this product.
    You can still use the lasercut stencil and 3.5x2.5 pcbs even if you change the ink however [noparse]:)[/noparse]
  • Jay KickliterJay Kickliter Posts: 446
    edited 2009-10-23 22:18
    Has anyone had success with this? I ordered the kit, but get errors most tries telling me to remove the tray and restart the printer.I bought a used R280 printer, so I have no idea where the problem is.
    edited 2009-10-23 22:28
    Several people other than me have had excellent success esp with double sided boards.
    Post your questions and read the hints in our forum: http://www.fullspectrumengineering.com/forums/viewforum.php?f=4&sid=6867ebb4381adfdc44f877307aca3baa
    edited 2009-10-23 22:30
    Also most likely you have covered up one of the registration holes and the printer won't let you accept the tray. Try printing with a regular CD then attach the holder to cover up the same spots a CD would (covered center is ok).
    edited 2009-10-28 11:06
    Xerox Improves Printable Electronics Via Silver Ink
    sounds like progress
    http://www.extremetech.com/article2/0,2845,2354850,00.asp
    edited 2009-10-28 18:34
    I doubt that conductance is very low on the printable ink.
    The sell a UV laser that will vaporize the copper and drill the holes. Probably set you back $30k-100k+ however.
    $100 Inkjet printer still cheapest way to go.
    edited 2009-10-29 14:15
    @fullspeceng.
    since you dont know what the current capacity is, how can you be so judgmental.
    most electronic interconnects only need microamps until the output,
    maybe they will do milliamps to drive LEDS at least
    check out the photo. notice the PCB ?
    http://digital.venturebeat.com/2009/10/26/xerox-developers-a-silver-ink-that-can-be-used-to-wearable-or-throwaway-electronics/
    edited 2009-10-29 14:56
    Silver has the best conductivity of all metals it would handle more then copper of the same thickness.
    24 bit LCD Breakout Board coming soon. $21.99 has backlight driver and touch sensitive decoder.
    I've read many printable ink papers and the conductivity was always much lower than copper.
    If you have any analog circuitry (motor control/ADC/DAC) then it will probably give you problems.
    Even if conductivity is excellent and comparable to copper, the article says the ink melts at 150degC.
    Leaded solder melts at 180C and non leaded usually around 220C. You can make RFID tags but not that useful as a PCB if you can't solder to it.
    Still I think any sort of science is cool so kudos to the researchers.
    I still think a UV laser machine would be very cool. I saw an ad on google for it. I will post it if I can find it.
