Logging values from a pressure- and position-sensors
I need to log the pressure in a diesel-engine cylinder, as well as the position of the piston. I thought of using a halleffect-sensor to determine the position of the output shaft(three sensors, with one magnet at the shaft, so I'll get the position every 120-degrees), and I got a pressure-sensor which has an output of 0-10V, depending on the pressure. This isn't all that hard to do with just a normal I/O-card and labview or something, but I need to do this at 1000rpm, and at that speed my USB I/O-card will not be fast enough to do this. So, is this possible with basicstamp? Is it able to store, say 360 pressure-values, position values at every 120-degrees, and put it in an array together with a time-stamp at every value? (at 1000rpm :P ) I need to log 2-3 revolutions, and of course export it to a PC.
I don't know what kind of pressure-sensor you have? They vary a lot.
The cylinder pressure from the engine would be read in an average pressure @ 1000 rpms. Trying to read each stroke is
wishful thinking.(Measuring pressure is to time consuming....mechanacal hysteresis)
You'll need an A/D converter for the BS2. Since the sensor is an analog signal..
Remember the BS2 is a 5volt device, So select your A/D converter accordingly
_______________$WMc%_________
The Truth is out there············································ BoogerWoods, FL. USA
