Accesories to implement into my projects?
· I have the··PS/2 to Breadboard Adapter·and connected to that I also have a PS/2 to USB Coverter. From that can I plug in any accesory such as a mouse, keyboard, or barcode scanner. I wanted to ask to make sure that I don't ruin my propeller chip or accessory.
If so, do any of you have some example programs for say, a barcode scanner? I know its kinda random.
Dan Taylor
Dan Taylor
As for barcodes, I was under the impression that most PS2 readers emulated a keyboard and sent char codes representing the barcode...· You probably just have to use the keyboard object to collect the data.
· Propeller Object Exchange (last Publications / Updates)
[noparse][[/noparse]Edit:] I thought you might want to know. That it is a laser bar code scanner. I don't know if that makes any difference.
Dan Taylor
Post Edited (Dan Taylor) : 9/2/2009 5:17:50 PM GMT
I also plugged the barcode scanner into my computer and it worked fine. Maybe the converter is the problem? Cause when the barcode scanner was plugged into my computer I could see the laser. But not when it is plugged in the the propeller.
Dan Taylor
I'd say you Propeller setup is correct, but obviously the bc reader does not like something.
One thought that comes to mind is your 5V source may not have enough current for the bc reader to operate properly.
Dan Taylor
I note the specs say it requires 165ma, I'm guessing that you are supplying that but what is your 5V source?
Finally, I can't run it, but is there any settings in the configuration utility that might be applicable?
I have plugged the bc scanner into the Propeller Demo Board.
Sorry I am kinda a newbie but, what is the Configuration Utility?
Dan Taylor
edit - corrected page
As for the configuration utility, no idea other than I found it on the manufacturers page.
