Propeller Robot Module
New video and picture for the PRM:
Video
Get it at gadgetgangster.com/171
Features:
) 3x push buttons for user input
) and LCD for displaying sensor data, stats, or debugging information
) 8 Servo outputs
) 8 multipurpose I/O pins to use for any external circuits/electronics
) 64kb EEPROM
) 8 Processing cores
) 32kb RAM
Specifications:
4"(w) x 3.05"(h)
Time required to build: ~2hrs
Brandon C.
No purchase necessary. See back panel for more details.
Tired of the same old robot brains? not enough processing power? Get the Propeller Robot Module now!!
Video
Features:
) 8 Servo outputs
) 64kb EEPROM
) 32kb RAM
Specifications:
4"(w) x 3.05"(h)
Brandon C.
I saw the board at UPENE and can't recall why I didn't buy one there. I do have one question though, it appears that the servos are powered by the same supply that powers the board. Is there any provision to run the servos from a separate supply?
Ron aka sailman58
With a little modification I am sure you could run the servos from a separate power supply. The voltage regulator outputs 3 amps. I was able to run all 8 servos, but with the LCD going a little dark because of low power. I plan on making a few changes to the board in the future to provide much more power for the servos.
Brandon C.
Post Edited (Brandon C.) : 9/2/2009 5:26:05 PM GMT
Open the Servo_Demo.binary with the propeller tool and click "Load EEPROM".
BTW there was a bug in the program which was causing the servo to jitter. I found out that each time the button was pressed I was telling the program to start the servo object, which was interfering if the button was pressed more than once.
Brandon C.
Post Edited (Brandon C.) : 9/2/2009 5:32:24 PM GMT
It would really be good if you could support more than eight servos, and particularly important to keep the servos on a separate power supply. You don't often want the servos to have a different power supply with more power, and you often need to turn the power to the servos off while you program. Still, looks like a great board and a real bargain.
My Robots
You could easily replace the jumpers between the pins and the headers with some 4.7k ohm resistors to add support for more servos, but extra resistors are not included. I am taking notes on everybody's suggestions and will make the necessary modifications in the next version.
BTW I am not sure if the board would really work for a BRAT robot, seeing as the board is kinda big (3" x 4.05")
Brandon C.
*adds "separate power for servos" to notes*
The reason why I think it would be great if someone would do this with the Prop is that the prop is much more powerful and it would be a much cheaper setup overall. The micro controllers they are using need to have a servo controller added in to handle the servos, so it is more expensive then what you are making.
My Robots
Nah, it's actually 3"x2.3". If you made a mount for the board, I'm sure you could easily place it on the BRAT. Although the PRM is better suited for small-large rovers. I am currently making a small rover using Lynxmotion SES parts that will use the PRM, but will take a few weeks to finish. I hope that when it is finished I can post the project.
Brandon C.
