Microsoft Robotics Developer Studio and HB-25 controllers with Wheel Kit
I just did a quick search and didn't find any posts about this so I thought I would ask the question.
I am building a robot using the Wheel Kit and the HB-25 motor controllers.· This robot will be built around Microsoft Robotics Developer Studio (RDS) on an ATX onboard motherboard using a Phidget USB servo controller to provide pulses to the HB-25 controllers.· To make this work I will have to write RDS services to control the wheel motors via the Phidget board and the HB-25 controllers.· This service should support the Generic Motor service and the Generic Drive service.
Before I ventured down this grueling road I thought I'd ask here if anyone has already done this.· Pointers are welcome.
Dogulas
Dogulas
Dogulas
Dogulas
www.whiteboxrobotics.com/Product/index.html
and the Robosoft Robudog
www.microsoft.com/windowsembedded/en-us/default.mspx
If they can do that with xp home/pro and xp embeded I think that would be the first thing to try since you already
have an ATX board.
here another with some interesting videos
the source code for the 914 api is farther down the page. you might be able to use the 914 api as is if you could find the same hardware the 914 uses.
914pcbots.com/community/
-dan
Post Edited (icepuck) : 9/2/2009 3:06:16 AM GMT
Thanks! These were great links. I actually haven't found what I'm looking for, but that tells me that this is probably new ground. I think I can now start thinking about doing the development myself.
Dogulas
Dogulas
1.)I have Intel Atom Kit , I have installed OS on it and we are using MDRS on it I have developed our needed application that is to voice commands to Control motors Rotation now after this we want to Simulate this .
2.)How I can actually control motors which will be communicating with our Pc serially using the above mentioned program made in VPL , how I can do this. i mean how we will interface motor so that they start working with MDRS code, do we will be needing a special chip for that or mdrs will create coomunication between pc and our motorcontroller. In TUtorial all refernce are for lego motors does that mean only lego nxt. can only be controlled , if I had a motor controller with 3 or 4 motor attached to it and my motor controller is serially communicating with my pc how i can control motor rotations , i can use any motor even servo that will not be an issue. plz tell the right approach for this,as i have make intensive search on net on this but i am not able to find any good solution.
plz help, we will be very thankfull to you
PS: some guy got one of the FEZ microcontrllers to work with the Android Phone SDK's, so know use a phone to control a robot....
Cheers.
