devices used for measurement in higher centigrade(500 C or more)
Frnds, what type/types of devices usually used in higher temperature environment and how to measure the temp ,in addition how much is the device compatible to basic stamp pdb?
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
*-NEW-* SD Card Adapter·Now available!· Add extra memory to your next Propeller project with ease!
- Stephen
I have supplied their 2 data sheets below. The MAX 6675 has a drawback, in that it requires a 250 ms pause. If thats not an issue, It is very easy to use. Both are designed to work with Type K thermocouples.
