Propeller II Current Status, Timeline, Package, Power, etc??? — Parallax Forums
WBA ConsultingWBA Consulting Posts: 2,938
edited 2009-09-04 20:55 in Propeller 1
I was digging through a few threads about new features/specs/requirements of the PropII, but couldn't find answers to the following:
1) What's the current design state of the PropII?
2) What's the current "guesstimate" at a product release date?
3) What package will the PropII be available in? I have seen mentions of PLCC84 and a DIP44(?).
4) I saw a post about multiple power requirements: 3.3v and 1.8v?
5) Could Parallax create a locked sticky thread for the above types of items as a preliminary datasheet?
Andrew Williams
WBA Consulting
WBA-TH1M Sensirion SHT11 Module
    edited 2009-08-31 23:28
    You will not find any answers to #1 or #2. Parallax does not provide that information.
    3) There will not be a DIP package. It's too expensive, particularly with only a subset of the pins available. There will probably be a DIP40 module like the SpinStamp with built-in regulators, EEPROM, crystal, etc., but that will not likely be available for a while after the Prop II is available. I believe the Prop II will require at least 80 pins.
    4) Yes. The core runs on 1.8V while the I/O pin circuitry runs on 3.3V and provides 3.3V logic levels.
    5) Probably not. There's really not enough hard information at this point. You'll just have to wait until the chip is closer to production. There is an unofficial Wiki with a summary of what has been discussed so far and links to discussion threads on those items (propeller.wikispaces.com/Propeller+II). Keep in mind that this is unofficial and very little is "hard".
  • JRetSapDoogJRetSapDoog Posts: 954
    edited 2009-09-01 04:11
    Uh-oh, my sometimes selective and/or wishful-thinking memory reports that the core·would run·at 1.8V, but groups of 8 I/O pins could run at either 1.8V or 3.3V (as a group) depending on how they were setup (wired?).· I thought I read that somewhere or heard it in a webinar (possibly from the "horse's mouth"), but now I'm worried that I might be wrong.· Hmm, that might·presume a dual-voltage supply.· I'm new to this, but I wish the dual-voltage capability were an option...because that could make interfacing with outside chips easier, such that voltage level shifters might not be required for the lower voltage stuff.· Anyone with a better memory (or crystal ball) care to set me straight?
    Post Edited (JRetSapDoog) : 9/1/2009 12:53:23 PM GMT
    edited 2009-09-01 04:17
    Okay, from a link off of the link that Mike gave I found this from Chip, "Each set of 8 I/O pins will have their own VIO pin (VDD for I/O). The pins can do lots of things at VIO=3.3V, but can still function well as digital-only I/O's at VIO=1.8V. At 1.8V, there are lower slew rates and drive strengths for outputs, but the digital input threshold is still around VIO/2, or 0.9V." Sorry, I should have checked first. Anyway, does this clarify the situation? I'm still not sure.
    edited 2009-09-01 05:49
    Regarding items 1 and 2 above regarding the development status of the Prop II, it's understandable/natural that many of us are "chomping at the bit," as it were.
    From reading this forum and viewing the webinars, it's fairly easy to tell that Chip would love to keep us as informed as possible. However, other powers-that-be at Parallax are reluctant to do so for various business and legal reasons, which is understandable, and perhaps even Chip reluctantly agrees. That's actually for our benefit, too. What if one of us planned a new product around the Prop II (as opposed to another MCU) but then the Prop II didn't come out "on time" as expected? Then, our product might miss a market-window of some sort, and we would wish that we had considered another solution (if another one was actually available, which might not be the case).
    During one of the mid-March webinars with Chip--one where participants were specifically instructed NOT to ask Chip about a release date--someone understandably asked anyway, and Chip was gracious enough to shed some light but no promises. At the earliest, the Prop II was 8 months away at that time, which would put it in the November 2009 time-frame as the earliest that anyone could reasonably hope for release (anything prior to would be a big surprise). On the other end, Chip indicated that it could be 12 months out (or more), which would put it into or beyond mid-March, 2010. That's the figure I'm using in my wishful thinking, though I'd love to be pleasantly surprised. However, even that figure was by no means guaranteed, nor has it been stated officially by Parallax. In fact, we must realize that the release of the Prop II is not guaranteed to ever come out, though it appears to be on-track and also among their highest priorities. That is, from what comments Parallax has made, one can surmise that they are making progress.
    I recall reading or hearing that the basic design of the 64 I/O-pin version of the Prop (Prop I) had been completed, but that there was a probem laying it out (or similar) in one of the design tools they use, and that problem had basically thwarted further development. So, what if something like that happened with the development of the Prop II? That could really throw a money-wrench into development and trash any anticipated release time-frame that was made in good faith. I mean, given that the Propeller design philosophy is at least somewhat different than most of the chips that have come before, it is easy to see how there could be something about the design of the Prop II that trips up one of the design tools Parallax uses to implement its design. And in that event, there's simply no telling how long such a problem could take to resolve, especially since the design software belongs to another company. In addition, even if the Prop II design makes it through the design tools okay, there could still be an unexpected glitch in actual silicon. As others have mentioned in various theads, Parallax seems committed to avoiding such glitches as much as is possible. So, it's wise for us to be patient, even though it's difficult.
    I'm NOT here to say that it's foolish to speculate about a release time-frame. I find this topic interesting, too! I think I once scratched a hole in the wrapping of a Christmas present because I didn't want to wait until Christmas (which is/was about as solid of a release date as one can get). After all, it's been five months, and it's only natural for us to kick up this topic again. But we can't demand or expect any definite answers. Perhaps the best we can hope for is some sort of casual statement from Parallax (or someone beyond the firing line) about whether any particularlly difficult to overcome problems have been encountered or currently exist.
    Anyway, for my part, I'd be happy to just see Parallax take down those "Register Now" button links on the Webinars page for webinars that took place back in June or before. That kind of looks odd, but I know they've got their hands full with various projects under development. I'd also be interested in seeing the last two webinar videos assuming that the participants didn't get into a "food fight" or something, but maybe Parallax feels that those events have nothing new to offer beyond what the other videos already provide (or perhaps they weren't recorded or the quality lacks). Anyway, in conclusion, overall, I'm quite happy with the level of support Parallax provides and the extent to which they keep us informed on the status of their doings. For example, recently, they provided an update on the Propscope. Having said that, it doesn't bother me at all when people on this forum bring up release dates...because it's interesting and one never knows when one might learn something new. As for me, I came to the Propeller late, so there's much to learn. And it seems that the original propeller has many applications (possibly heretofor untapped) still ahead in the future.
    edited 2009-09-01 06:41
    Mike said...
    Maybe they will make one of those shmart boards for it.
    Or maybe Sparkfun will make a little board to mount it on.
    Someone here who is good at layout could design a board and we could
    make a group buy from a china circuit board company?
    - Some mornings I wake up cranky.....but usually I just let him sleep -
    edited 2009-09-01 06:48
    Maybe by watching the items offered on the daily deal we could gain some insight
    about the prop2 release date.
    They may try to reduce the stock of various items that might lose a bit of appeal
    once prop2 is available for sale.... they won't want to be sitting on a warehouse full
    of prop1 stuff that might take years to reduce.
    Prop 1 pro dev board?
    DIP version of prop1?
  • hinvhinv Posts: 1,255
    edited 2009-09-03 13:16
    I don't think the demand for the dip version of the prop1 will decline that much when the prop II comes out as the boards like you described will lag a bit, and will still be unweildy for a lot of prototype applications. People like the Dip40 form factor.
    Now dropping the prices on the prop1 across the board seemed to be a indication to me, but that was months ago.
  • Luis DigitalLuis Digital Posts: 371
    edited 2009-09-03 14:30
    Yes Parallax/Chip, some new info about Propeller II is good idea.
    The leader has much time in silence. [noparse];)[/noparse]
  • Agent420Agent420 Posts: 439
    edited 2009-09-03 14:40
    >· People like the Dip40 form factor
    They also like all the power and features ;-)· Nearly all hobby / project oriented items are available in some kind of dip module form as well, so I don't think the chip format itself is going to be a big deal.·· But imo things like increased ram are going to open up possibilities for the Prop II that we would like to implment with the current Prop, but simply can't fit in or run out of cogs.
    I can see the Prop II influencing Prop I sales, but pricing will probably keep things in line and continue demand for the current chip.·
    edited 2009-09-03 15:03
    Keep in mind that Parallax is a small company and the major decision makers can all sit comfortably around a small table and are the same people who are actually doing the work. There's no separate marketing department "calling the shots". Chip and the others involved have all experienced and spoken about marketing-driven engineering and have been very clear that it's not the way Parallax works. When the product is ready, it'll be announced and available. When it's ready, it'll be reliable, well-crafted, etc.
    Holly,
    Others have mentioned before that Prop I and Prop II will serve somewhat different needs because of the differences in chip technology used. The Prop I will be cheaper than the Prop II and cheaper to use. The package (because of the number of pins) will be cheaper. You won't need a 1.8V regulator. The Prop I will take less power since the manufacturing process for the Prop II uses smaller features which leak more current.
    Keep in mind that Parallax still sells the BS1 and still sells the BS2 even though the BS2px is faster, has more memory and more features. The BS2pe, which is intended for datalogging applications, has a larger run current than the BS2 and the BS1 still has the lowest.
  • blittledblittled Posts: 681
    edited 2009-09-03 16:29
    I heard some things at the UPNE from Chip. This is from memory and as I age that gets harder to pull from [noparse]:)[/noparse]. So don't take this as "hard and fast" facts.
    1. Chip mentioned 8-12 months for the release in August.
    2. The company that they looked at to do the silicon no longer offers that service. They are looking at another company that will do it within the current tool chain Parallax uses.
    3. As Mike mentioned there will not be a dip version but Chip said they will provide·a hobbyist friendly breakout board at an additional cost.
    4. The cost of the Propeller II could possibly be only 50 cents more than the Propeller 1 per unit.
    What electronics need - MORE POWER!!!!!!!
    Post Edited (blittled) : 9/3/2009 4:36:32 PM GMT
    edited 2009-09-03 18:09
    @Mike Green
    Since it sounds like the prop2 will have 2 different supply voltages
    wouldn't it be handy if someone made linear regulators like the
    78xx series but with a 4th pin.
    In, OUT3.3v, GND, OUT1.8v
    And while we are at it just add an OUT5.0v
    Would be great if you could get such a beast
    at the low price you can get 78xx regulators in quantity.
    Or maybe such handy parts do exist and I just don't know about them?
    Even better would be if the regulator was in the chip itself and could be fed
    directly from a 7-12v source. It would heat up the prop2 but after seeing
    that demo where they roasted the prop1 in an oven and it kept working
    a little heat from a regulator seems survivable.
    Tiny circuit boards to make a sm prop2 easy to use
    should be cheap. There are Chinese board makers
    that will make up a large panel full of small designs
    and cut the whole thing up for you at a really good
    price. All you would need to do is solder the prop2
    down and add some pins for easy connection.
    Solder paste and a hot skillet should even work...just
    put the prop2 on a little crooked and the instant
    you see surface tension pop it into alignment
  • VaatiVaati Posts: 712
    edited 2009-09-03 18:20
    Ummm... I remember Mr. Gracey saying that the Prop II will be in a 100 pin LQFP package. smile.gif Also, he said that the die is too big for a DIP package, and that there will be a total of 64 I/O pins. I forget the other stuff, but he said that there will be all new dev stuff for it as well.
    I can't wait to see a prop II demo board: there would be sockets for the I/O pins surrounding the breadboard.... smile.gif
    Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
    *-NEW-* SD Card Adapter·Now available!· Add extra memory to your next Propeller project with ease!
    edited 2009-09-03 20:56
    Quad packages are still manageable for a lot of hobbyists, as long as the pin pitch is left as BIG as posible. Extremes of small may be cute for commercial manurfacture but would be useless for the eyes and fingers like mine. QFN Prop1's are no good to me
    The DIP advantage was ease of assembly coupled with bases so projects A, B, C ... could be tried without having to tie up/ throw away Props. I only have three props and at UK prices (until recently) £40+ total on those chips was about all that was going to be put out, without evaluation boards for other platforms becoming atractive.
    I really look forward to the PropII but will have to plant it onto a "DIP" carrier and use it for more than one thing.
    Style and grace : Nil point
    edited 2009-09-03 21:12
    If the prop2 is in a 100pin package then there will
    certainly be opportunities for someone to buy them in
    large lots at a good price and have them mounted on
    various types of dev and carrier boards.
    I suppose one of those China board plants that
    offers cheap assembly of parts to the boards might
    be a way to go. I guess you would have to ship them
    the props? or maybe they would order them directly
    after you paid for the finished boards.
  • W9GFOW9GFO Posts: 4,010
    edited 2009-09-03 21:24
    China China China, it just might be possible to accomplish that right here in our own country without resorting to outsourcing. It's next to impossible to not participate in outsourcing but in cases like this it would be real easy to avoid. I will gladly pay a little more to keep jobs in my country.
    Rich H
    The Servo Boss, a 12 channel servo tester kit from Gadget Gangster.
  • CounterRotatingPropsCounterRotatingProps Posts: 1,132
    edited 2009-09-03 21:42
    I'm with you on that one, W9GFO - Ken mentioned here not long ago that they prefer to do whatever work they can here at home, hopefully that will apply to the PII as well.
    I'm not against cheap parts, or overseas manufacturing, per se... but I'd rather help a local neighbor before a distant one, IYKWIM.
    - H
    edited 2009-09-03 22:03
    It would be nice to make that sort of thing here.
    But I think it would wind up being not a little bit more$
    but a lot more $.
    Like maybe the difference between being able to sell an 18.00 carrier board
    vs a 29.00 one. If nobody competes with you at a better price you will make
    the same $ selling the 29.00 one but if you sell them for 18.00 then lots
    more people get to buy one. Fewer people able to buy tech gear to play
    with means fewer local innovators, fewer local entrepreneurs and eventually
    fewer local jobs....unintended consequences. Pay more and buy US
    might hurt employment more than it appears to help. Sometimes obvious
    answers that seem to be common sense solutions are not thought out well enough.
    I'd like a board house located in India better than one in China.
    At least they are a democracy.
    There is just no way the US can hang on to low-skill jobs that pay 20+/hr
    when so many other places have drastically lower wage levels.
    Tariffs is an idea but that has been tried before and was disastrous...so
    I see no simple solution.
    We have to compete with brains, we can't compete with low wages because
    you can't live in the US if you make wages that are anywhere near those
    in Asia. So until desktop assemblers manufacture most items for you
    in your own home we have to buy from Asia.
    Nearly ever part on everything you buy was made in Asia... that would include
    the parts on the controller boards we all buy....no way to change that.
    Even our military gear is mostly made of Asian parts...that sure seems
    risky.
    Post Edited (HollyMinkowski) : 9/3/2009 10:12:29 PM GMT
  • Guns of FunGuns of Fun Posts: 26
    edited 2009-09-03 23:07
    And don't forget the toxic chemicals used in silicon manufacturing.· I think cyenide is one of them.· China doesnt have to worry about EPA and OSHA.
    edited 2009-09-03 23:13
    Were talking simply a carrier board right? One board, one chip and two rows of headers. The board itself would cost about two dollars, the labor to assemble one chip and two rows of headers is, lets say $2 as well, the parts may be $10. So that is $14 if made in the USA. The bulk of the price then is due to the chip and the amount of profit you want to make.
    Rich H
    edited 2009-09-04 00:08
    Mike, thanks, that's what I was looking for. I know Parallax is still wrapping things up, but the Wiki has the level of detail I expect at this stage.
    As for the DIP40 package of Prop 1, I doubt it will go away until they obsolete the Prop 1 which is years (decades?) out. It's just way too easy to use a DIP package for schools, development, etc. Cheap education kits using the Prop1 will not be obsoleted by the Prop2.
    Andrew Williams
    WBA Consulting
  • LeonLeon Posts: 7,620
    edited 2009-09-04 03:19
    HollyMinkowski:
    Maxim makes a dual output regulator like that, the MAX8882. I got a couple for use with an ARM chip, they work OK. It's in a tiny SOT23-6 SM package.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
  • BigFootBigFoot Posts: 259
    edited 2009-09-04 03:26
    We have an immediate use for them, our firmware group spends all there time refining code so it will fit into 32K.
    Russ
    edited 2009-09-04 03:28
    edited 2009-09-04 03:38
    HollyMinkowski said...
    I...China.... be opportunities... China... a good price.... China... way to go..... China... China.... China....
    W9GFO said...
    China China China....
    All this talk about China reminds me of advice I was given years ago:
    Heaven is...
    A Chinese cook
    A Japanese wife
    An American salary
    and an English house
    Hell is...
    An English cook
    An American wife
    A Chinese salary
    And a Japanese house
    edited 2009-09-04 11:38
    I dont think everybody would want 40 pins just because that was the old choice.·A few·will require all 100, or close to it, and have one whale of a carrier although most breadboards would resrict it to 64, whilst some might be able to use just 20 or so, using the P2's internal bits. So perhaps a small range could me made available.
    Also possible would be a single universal board with 8 way (or so ) jumper sets with 0.1" header that will fit Breadboards ( and not require a crowbar to remove them ) then as many or as few pins as needed could be accessed.
    Any clues as to the power consumpsion and heatsink requirement, that will set dimensions, rather than the package.
  • James LongJames Long Posts: 1,181
    edited 2009-09-04 11:57
    I just wish I had some idea of the possible end packages. I could already have carrier boards made for the prop II and start mounting some when the chip is released.
    J Long
    James L
    Partner/Designer
    Lil Brother SMT Assembly Services
    Please note: Due to economic conditions the light at the end of the tunnel will be turned off until further notice. Thanks for your understanding.
    edited 2009-09-04 15:04
    ElectricAye, Re: Heaven is... So true.
  • AleAle Posts: 2,363
    edited 2009-09-04 20:30
    Visit some of my articles at Propeller Wiki:
    MATH on the propeller propeller.wikispaces.com/MATH
    pPropQL: propeller.wikispaces.com/pPropQL
    pPropQL020: propeller.wikispaces.com/pPropQL020
    OMU for the pPropQL/020 propeller.wikispaces.com/OMU
  • Nick MuellerNick Mueller Posts: 815
    edited 2009-09-04 20:42
    I wouldn't bother about the SMT. I bet Parallax will design a daugtherboard that makes the Prop II more or less pin-compatible to the Prop.
    Nick
    Never use force, just go for a bigger hammer!
    The DIY Digital-Readout for mills, lathes etc.:
    YADRO
