Multiple Prop Names - Fill In the Blanks — Parallax Forums
HumanoidoHumanoido Posts: 5,770
edited 2009-09-01 06:02 in Propeller 1
Multiple Prop Names
from Greek and Latin
1- MonoProp or UniProp
2- DiProp or BiProp or DuoProp
3- TriProp
4- TetraProp or QuadProp
5- PentaProp or QuintProp
6- HexProp or SexProp (not recommended)
7- HeptProp or SeptProp
8- OctoProp
9- EnneaProp or NonProp (not recommended)
10- DecProp
11-
12- DoDecaProp
13-
14-
15-
16-
17-
18-
19-
20- IcosaProp or VigintProp
21-
22-
23-
24-
25-
30- TriacontaProp or TrigintProp
40- TetracontaProp or QuadragintProp
50- PentacontaProp or QuinquagintProp
60- HexacontaProp or SexagintProp
70- HeptacontaProp or SeptuagintProp
80- OctacontaProp or OctogintProp
90- EnneacontaProp or NonagintProp
100- HectProp or CentProp
1000- KiloProp
1,000,000- MegaProp
1,000,000,000- GigaProp
1,000,000,000,000- TrillProp
1,000,000,000,000,000,000,000
,000,000,000,000,000,000,000,
000,000,000,000,000,0- GoogolProp 10^(10^2)=10^(100) which is a 1 with 100 zeros following it
10^(10^(100))- GoogolplexProp
Infinity Numbers- InfiniProp
Aleph-0-Prop- the "small" infinite set of integers
Aleph-1-Prop- smallest infinite set of Propellers larger than aleph_0_Prop (Aleph-0-Prop), which in turn is equal to the cardinality of the set of countable ordinal numbers of Props
Multiple Prop Names from Humor
13 - TeenProp
14 - MyDaughterIsInHighSchoolProp
15 - GotMyPermit!Prop
16 - PleeeezeBuyMeACarDad!Prop
17 - YippieGraduatedHighSchoolProp
18 - AgeOfConsentProp -or- YouCanJoinUSArmyButStillNotDrinkProp
21 - OkToBuyBeerProp
23 - ShouldHaveDegreeByNowProp
00 - NotAProp- when the Prop chip is not in stock
PromProp- Props get together on the big night
18 - PalmiProp (from palmitic acid)
22 - FishaProp (some fish fats have 22+ carbons fatty acids)
60 - BuckyProp (find yourself why)
53: B-DayProp (today, mine, grease up to the ellbows fitting new glass-scales to the mill)
24 - GordonProp (a prop based device that shows Jeff Gordon's current stats from nascar.com????)
37 - I'm37I'mNotOldProp (From Monty Python's Holy Grail)
762 - FeynmanProp (Feynman Point)
777 - HolyProp (Use OBC's Ham Radio Tester program but put the Bible on the SD card???)
HalloweenProp (for Oct. 31st)
NewProp (the Prop II)
GotAProp (happy new owner)
TopProp (showing its rating)
StopProp (the buck stops here)
DropProp (takes licking and keeps ticking)
OpProp (dedicated operands and op code)
DotProp (smaller than 44-Pin QFN Chip)
ShrunkProp (went through the washing machine)
PiProp (3.1415... )
Post Edited (humanoido) : 9/1/2009 6:12:57 AM GMT
    edited 2009-08-31 16:15
    1000- KiloProp (dead??)
    1,000,000- MegaProp
    1,000,000,000,000- TrillProp or TetraProp?
    Now only Bill can afford these but since they don't run windoze I suppose he's not interested.
    · Home of the MultiBladeProps: TriBladeProp, RamBlade, TwinBlade,·SixBlade, website
    · Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
    · Search the Propeller forums·(uses advanced Google search)
    edited 2009-08-31 16:27
    Thanks Cluso. Keep these coming and the list will be revised.
    The challenge: How complete (and big!) can we make this list???
    Hey! Don't worry about Bill. Maybe we'll do some kind of virtual
    gadzillion prop emulator all in software!
    humanoido
  • jazzedjazzed Posts: 11,803
    edited 2009-08-31 16:39
    Humor me [noparse]:)[/noparse]
    13 - TeenProp
    --Steve
    Propeller Tools
  • heaterheater Posts: 3,370
    edited 2009-08-31 16:42
    GoogolProp
    A GoogolProp is a large number or Propellers equal to 10^(10^2)=10^(100) (i.e., a 1 with 100 zeros following it) Propellers. Written out explicitly.
    GoogolPlexProp
    A GoogolplexProp is a large number of Propellers equal to 10^(10^(100)) (i.e., 1 with a googol number of 0s written after it) Propellers.
    InfiniProp
    An InfiniProp ... well, you know, much much bigger than that number of Propeller chips.
    Aleph-0-Prop
    A set of Propeller chips having the same cardinal number as the "small" infinite set of integers. Bit like an InfiniProp.
    Aleph-1-Prop
    The smallest infinite set of Propellers larger than aleph_0_Prop (Aleph-0-Prop), which in turn is equal to the cardinality of the set of countable ordinal numbers of Props.
    Definitions mangled courtesy of WolframMathWorld.
    edited 2009-08-31 16:51
    NotAProp
    There is Not A DIP Propeller chip availabe.
  • AleAle Posts: 2,363
    edited 2009-08-31 20:18
    I propose:
    Visit some of my articles at Propeller Wiki:
    MATH on the propeller propeller.wikispaces.com/MATH
    pPropQL: propeller.wikispaces.com/pPropQL
    pPropQL020: propeller.wikispaces.com/pPropQL020
    OMU for the pPropQL/020 propeller.wikispaces.com/OMU
  • Nick MuellerNick Mueller Posts: 815
    edited 2009-08-31 20:28
    53: B-DayProp (today, mine, grease up to the ellbows fitting new glass-scales to the mill).
    Nick
    Never use force, just go for a bigger hammer!
    The DIY Digital-Readout for mills, lathes etc.:
    YADRO
    Post Edited (Nick Mueller) : 8/31/2009 8:33:30 PM GMT
    edited 2009-08-31 22:17
    Happy Birthday Nick!
    --Steve
    Propeller Tools
    edited 2009-08-31 22:22
    Nick
    YADRO
    edited 2009-08-31 22:26
    Jeez. Ok, but it's still your birthday in California [noparse]:)[/noparse]
    --Steve
    Propeller Tools
    edited 2009-08-31 22:29
    Andrew Williams
    WBA Consulting
    WBA-TH1M Sensirion SHT11 Module
    edited 2009-09-01 05:06
    Updated and wonder if the humor section is going to exceed the serious section... [noparse]:)[/noparse]
    edited 2009-09-01 05:16
  • TubularTubular Posts: 4,774
    edited 2009-09-01 05:31
    Pretty sure 12 would be DoDecaProp
    edited 2009-09-01 05:33
    Although I don't understand the point of all this?
    How about
    3.1415... PiProp
    Clock Loop said...
    We are building multiple prop circuits and the names come in handy.
    For the higher numbers, the names will be useful for emulation and
    various projects, even theoretical papers or doodling. A humor section
    was started by jazz for the lighter side.
    PiProp name... I can see where someone may want to
    dedicate their prop to calculating Pi out to a high number of places
    using special floating point routines.
    humanoido
