74hc164 Schematic & Sample Code
Hello,
I need to free up some pins from my Stamp2 application. After doing some digging and research it appears that the simplest way to do this is via a 74hc164 for inputs and a 74HC595 for outputs. I dug and for the life of me I can't seem to find a simple example of how to build a circuit along with sample code. I just know there is a Nuts & Volts article out there waiting that covers this. . .I found one, but it looks like they are using a totally separate PIC microcontroller and I'd like to avoid that if I can.
Any suggestions/pointers?
-JEff
-JEff
Schematics (with 8 LED's connected):
Code:
' {$STAMP BS2p} ' {$PBASIC 2.5} pHCIO CON 0 ' 74HC595 data pHCCLK CON 1 ' 74HC595 clock pHCLtc CON 2 ' 74HC595 latch Main: HCBits = %01000100 GOSUB WriteHC END WriteHC: SHIFTOUT pHCIO, pHCCLK, MSBFIRST, [noparse][[/noparse]HCBits] PULSOUT pHCLtc, 1 PAUSE 50 RETURN74HC165
Schematics (with 8 switches):
Code:
' {$STAMP BS2p} ' {$PBASIC 2.5} ' This program demonstrates a simple method of turning three BASIC Stamp ' I/O pins into eight digital inputs with a 74HC165 shift register. ' -----[noparse][[/noparse] I/O Definitions ]------------------------------------------------- Clock PIN 0 ' shift clock (74HC165.2) SerData PIN 1 ' serial data (74HC165.7) Load PIN 2 ' output latch (74HC165.1) ' -----[noparse][[/noparse] Constants ]------------------------------------------------------- DelayTime CON 100 ' -----[noparse][[/noparse] Variables ]------------------------------------------------------- switches VAR Byte ' switch data ' -----[noparse][[/noparse] Initialization ]-------------------------------------------------- Reset: HIGH Load ' make output and high DEBUG CLS, "Switches 76543210", CR, "-------- --------", CR, "Status ........" ' -----[noparse][[/noparse] Program Code ]---------------------------------------------------- Main: DO GOSUB Get_165 ' get switch inputs DEBUG CRSRXY, 10, 2, BIN8 switches ' display current status PAUSE DelayTime ' pad the loop a bit LOOP ' -----[noparse][[/noparse] Subroutines ]----------------------------------------------------- Get_165: PULSOUT Load, 5 ' load switch inputs SHIFTIN SerData, Clock, MSBPRE, [noparse][[/noparse]switches] ' shift them in▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Don't worry. Be happy
' {$STAMP BS2p} ' {$PBASIC 2.5} pHCIO CON 0 ' 74HC595 data pHCCLK CON 1 ' 74HC595 clock pHCLtc CON 2 ' 74HC595 latch HCBits VAR Byte Main: HCBits = %01000100 GOSUB WriteHC END WriteHC: SHIFTOUT pHCIO, pHCCLK, MSBFIRST, [noparse][[/noparse]HCBits] PULSOUT pHCLtc, 1 PAUSE 50 RETURNAlso, forgot RETURN statement in the 165 code snippet.
I do still have one remaining question though. . .is it possible to read the current position of the outputs controlled by the 75HC595? The examples provided and the ones I found show how to write and change the state, but not necessarily how to read the state of all the switches. I really need to be able to do both. . .
-Jeff
Post Edited (everest) : 8/31/2009 1:18:24 AM GMT
-Jeff
How would I write Activity #3 from Chapter#3 using· the 74HC165?· Here is the input from the book:
' {$STAMP BS2}
' {$PBASIC 2.5}
' Whats a Microcontroller - CH3ACT3PushbuttoncontrolledLED.bst
' Check· pushbutton state 10 times per second and blink LED when pressed.
DO
· DEBUG ? IN3
· IF (IN3 = 1) THEN
··· HIGH 14
··· PAUSE 50
··· LOW 14
··· PAUSE 50
· ELSE
··· PAUSE 100
· ENDIF
LOOP
I have the·attached schematic wired up with my BS2... but frankly I don't know what my input labels will be (IN3 above will be what now that I have· an input going through the 74HC165 chip???).· Am I thinking about this the wrong way?·
Any advice out there?· Please be specific... and dumb it down for me a bit.
Thanks!
Kevin
