Propeller RFID Reader
Hey,
Now that I've got an RFID card from UPENE, I'm trying to figure out what to do with it... I saw the Parallax RFID reader on the back my Nuts & Volts magazine, and I remember the coil wrapping I did to make the Propeller an inductive sensor, and I was thinking... could the Propeller be an RFID reader? It looks like it needs to oscillate at 125KHz, which the prop can do, and I assume sense some changes to be able to demodulate the signal (which I also assume it could do). Has anyone tried this, or have any ideas how it could be done? Or, I guess, does anyone have any good links on how the tags work?
Oh, and how about emulating a tag... I assume that would be possible as well?
DogP
DogP
For the coil I just purchased some Radioshack magnet wire and wrapped it around a CD spool case. I did some rough air coil calculations to get the ballpark number of turns required and then removed turns until I got the highest peak voltage across the LC tank (a scope is very handy for this).
DogP
