Adc tlc2543 accuracy
I am new to the forum and have been trying to work this problem out but can't seem to.
So any help would be appreciated.
Using BS2 with USB BOE.
TLC2543 with shortest wires possible.
Using Tracy Allen's code for this chip and it does work very well only using one input·channel for now, code has not been altered wanted to make sure it was working correctly before I changed it at all.· Since this project is for·reading a 0 - 5v transducer I thought I would start with variable power supply for an input to the TLC2543 instead of an actual transducer.· Here are my results
Input············· Output (debug screen)
508mV··············· 507mV
1.006V···············1.005V
1.506V···············1.510V
2.0V················· 2.006V
2.5V··················2.507V
3.006V················ 3.017V
3.504V··············· ·3.515V
4.006V··············· ·4.517V
4.998V···············4.998V
Is this typical, don't believe it would be power supply noise / ripple since the lower and upper voltages and good.· Accuracy is very important because the project requires a .2PSI accuracy range.
Thank you
Thank you
- Stephen
Tracy Allen
www.emesystems.com
Power for the chip is coming from the VDD & VSS connectors on the BOE
Reference is connected to VDD & VSS.· (VDD is 4.997V)
Input to the channel is a variable power supply 0 - 5V simulating a transducer (typical bench supply Protek)
Verification of input voltage is done by a Fluke DVM.
I will go back and again verify my voltages.
Is it possible that my fairly typical breadboard layout could have crosstalk with wires next to and crossing over each other?
You mention short leads on the chip. Have you also connected a bypass cap to the power supply pins?
While it shouldn't matter, are the unused channels pulled low?
Cheers,
Tom Sisk
http://www.siskconsult.com
After that I will put in a ·bypass cap to see if that also helps.
And all the other channels are floating.
Just so I know what is causing this issue it will be done in steps instead of all at once.
Greg
from 8/29:
3.006V 3.017V
3.504V 3.515V
4.006V 4.517V
4.998V 4.998V
from 9/7:
3.006V 3.017V
3.504V 3.515V
4.006V 4.517V
4.998V 4.998V
Huh?
In any case, it's hard to explain the TLC2543 reading being 0.5 volt high at 4.006 volt input. I'd take a few more readings between 3 and 5 volts in order to zoom in on the error. If it is a circuit problem, I'd agree with Tom and start by looking at the power supply. Maybe there are serious spikes in supply or reference. However, noise on the supplies usually appears as inconsistent readings.
Tracy Allen
www.emesystems.com
