Index and length must refer to a location within the string.
Dear All
I often get the following annoying error with the code (in ViewPort) below. Sometimes the code works fine, and sometimes I get this error.
What am I doing wrong?
Parameter name: length
Debugger USER INTERFACE
The code is as follows:
=PUB Cull_excess_population | n
= repeat while Current_Population_Size > max_population_size
= n := || rr.random // Current_Population_Size + 1
= repeat while n < Current_Population_Size
= Chromosome[noparse][[/noparse]n] := Chromosome[noparse][[/noparse]n+1]
= n++
= Current_Population_Size --
TIA David Young
= n++
TIA David Young
You've really got to start posting your programs between [noparse][[/noparse]code] and [noparse][[/noparse]/code] tags, at the very least; or use the code formatter at www.phipi.com/format. Without doing so, your indentations disappear.
tags ................
Not everyone knows what you're talking about! Can't be too hard to give an example can it?
TIA David Young
If it's still too confusing, just read the forum help page here: forums.parallax.com/forums/help.aspx. Look under the mcode reference at Code.
Hope the formatting's OK.
PUB Cull_excess_population | n repeat while Current_Population_Size > max_population_size n := || rr.random // Current_Population_Size + 1 repeat while n < Current_Population_Size Chromosome[noparse][[/noparse]n] := Chromosome[noparse][[/noparse]n+1] n++ Current_Population_Size --I'm not familiar with ViewPort, but it looks from your code that you're assuming that array indexing is 1-based. In Spin, arrays begin with subscript 0. So I think what you want is this:
PUB Cull_excess_population | n repeat while Current_Population_Size > max_population_size n := || rr.random // Current_Population_Size repeat while n + 1 < Current_Population_Size Chromosome[noparse][[/noparse]n] := Chromosome[noparse][[/noparse]n+1] n++ Current_Population_Size --Also, you can save a lot of compute time if you use longmove (assuming your chromosomes are longs), instead of the repeat loop.
Thanks. I'll work on that.
TIA David Young
