XBee Modules and the BASIC Stamp
velociostrich
I bought two XBee modules for a project of mine, but from what I've read, stamps cannot directly output signals to the XBee, given their 5V logic levels as compared to the XBee's 3.3V.
I see that the AppBee from SelmaWare uses the 74LVC244A to "condition" the BASIC Stamp's 5V logic levels to the XBee's 3.3 -- an IC that I don't have -- so I'd like to know if it is possible to just use resistors.
Furthermore, does the XBee require its own voltage regulator (at 3.3V)? I would assume that because of its variable current draw, I could not "just" use resistors, right?
I don't know for sure if a series resistor in each Stamp output to xBee input connection will work. Try a 3.3K or 4.7K resistor to limit the input fault current to a couple of hundred microAmps. The 74LVC244A or other voltage translator would be better, but the resistors may be enough.
Link:
http://www.adafruit.com/index.php?main_page=product_info&cPath=29&products_id=126
Dave
Xanatos, your solution sounds wonderful -- I'll give that a try.
Don't worry. Be happy
