Ping question.
Sorry if this is not the correct forum.
I'm interested on using 4 Ping sensors to measure 4 object's distance, in a four column (parallel vectors) array, my question is:
Is there a safe distance between Ping sensors to work measuring distance in parallel vectors?
Gustavo
Gustavo
Thanks for your answer, I will calculate if the "sequential" option allows me to get the refresh rate I need, probably yes, anyway interference could be a poblem.
Do you think it can be used some kind of cylindrical chamber to reduce ultrasound propagation angle? I just need to measure distance on a 10cms diameter column for about 50cms.
