Odd VGA output on known circuit
I have a build of boards, know working circuit and program (standard Prop VGA output using 8 resistors).
VGA output lines are progressively smearing horizontally upon start. First time I have seen this, in about 50 boards.
I thought it might be a bad crystal, so I changed the crystal, and get the same result.
Anyone have any thoughts??? Bad Propeller perhaps???
Thanks for any input!
John
Whistler: I want peace on earth and goodwill toward men.
Bernard Abbott: We are the United States Government! We don't do that sort of thing.
Sneakers (1992)
John
Sneakers (1992)
The pixels in the image that come up on this one board, the smear from left to right. The longer the propeller runs, the more the pixels smear (a clock issue of some sorts?). This is using the VGA Tile drivers. If if it were resistors to VGA connector, colors would be off, caps are on the power side, eprom works fine, I changed crystal (2 bad in a row??), that leaves the propeller.
I don't know, I'll move on to the next board for now.
John
Sneakers (1992)
www.jrbtechnical.com/media/DSCN2033.wmv
John
Sneakers (1992)
Can you post a picture of your board layout and schematic, please? This may be a matter of the PLL going flaky due to power distribution/bypassing issues.
This has to be a component issue, as there are many of these units that have been working for almost 9 months. Circuit hasn't changed, program hasn't changed.
You think PLL going flaky - then I guess I should probably chalk it up to a bad prop chip.
John
Sneakers (1992)
Sneakers (1992)
