Quick question about Prop and Servos...
I know servos work well when the power supply is 5V.
Can I connect a prop pin directly to the control and do the PWM with it only being 3.3V, or do I need to amp the voltage level on the signal up to 5V?
Shaun
Shaun
Dave
I am in the process of replacing (4) 150 ohm resistors on my prop interface to servos to the 1K you suggest. I started with the 150 ohm resistors as that was what is used on the prof. development board.
Thanks for your posts, this forum is very helpful...
Dave
