Robot gone wrong?
I'm so fed up with things not working out on my robot I was wondering about some of the other stories forum members might have pertaining to things not going right on their robots. Go ahead and spit it out, might make me feel better (or you, for that matter).
PG
PG
1. Build a 80lb bot that is RC controlled and dont check that the joystick centering controls havent been played with before turning on. Remote kill switch got built quick!
2. Make a mistake charging a 12V 18Ah battery and short the battery. Lots of sparks, flames, melted metal, battery still works [noparse]:)[/noparse]
3. First omnibot I built had very bad traction, not enough and not consistent. It moving was funny to watch - kind of semi-controlled sliding. You ended up spinning the bot so all 4 wheels got traction then started it in the direction you wanted it to go, then as it lost traction and went off course, spin it to get back on course. Trying to write code to drive it in a direction was an exercise in frustation.
4. Drill a hole in a prop protoboard to mount something and forget to check where the programing pcb traces ran. Drilled most of the way through one of the traces. Board suddenly stopped being able to be programmed a couple of days later - fun finding the mistake.
-Converting a rc car to a robot, had it constantly skipping loops and running into things, probably due to power. I just about had it but was going to try one more thing to make it work and the servo controlling the wheels burned out. Needless to say the frame is currently in my junk pile.
-Worked for ages on the mechanics of my current gas-powered robot and finally got everything ready for the engine to be mounted on it. When I tried to start it, it suddenly wouldn't work. I took it in to the mechanics teacher and had him look at it, but he couldn't find out what was wrong. I took it in to the shop I got it at and he said it was the carburetor. Two days later after cleaning the insides from what looked like apple juice I finally got it running. To this day I still wonder if some idiot poured something into the gas while it was in the shop.
-Today, I had everything ready to finally make my robot autonomous. I had the transistors all set up to run the steering and all I had to do was make some code to get it running. When I was all ready I tested it and found the motor wasn't turning very well one direction. I tested it more feeling how much heat was coming off of the transistor and it finally stopped working altogether. I found a replacement to try instead out of an old drill and it didn't work as I expected, so I changed the wiring. Ended up blowing up in my face. Naturally, when I gave up and went to RS they didn't have any transistors, totally blowing the whole days plans. So much for a great end to the summer.
PG
One of the cool things about going to robogames was meeting other people with robots, all of whom had stories about how their robots had broken at various times and in various ways. Robot builders understand. You are trying to make something new. If it was easy, everybody would be doing it. So be proud.
My Robots
Got that right, Phil. Cracked me up, thanks. I can't say just how many hot-glued electronic projects went down the same path, but it is a lot.
"If it was easy, everybody would be doing it"
Yup, but I always seem to overcomplicate everything.
SRLM, isn't hardware just the hardest part of all? I guess that's why I like it.
PG
Post Edited (Prettybird) : 8/27/2009 1:12:22 PM GMT
you started this thread to let folks blow off steam - but it turns out to be quite a 'stress reliever' for the readers too... funny stuff (after the fact, of course [noparse]:)[/noparse]
> Back in my early TRS-80 software days,
> ... a call ... his homemade robot had run amok and could I please come take a look at it?
> ...."I've got it backed into a corner, and ... "
PHIL - so You are the very TRS-80 software guy that didn't come to the rescue?!!
You know, ever since that day, they've called me " peg-leg "
LOL - Just kidding (or am I ?) hehehehe
I did a ton of work on the TRS-80 back in the day and never had any odd calls like that.
Robert
I know this will make you feel better! (based on previous comments!
http://www.youtube.com/watch?v=ASoCJTYgYB0
Pay no attention to the man behind the movable screen...
Whit+
Post Edited (Whit) : 8/28/2009 1:59:58 AM GMT
CRP, I'm sorry about your leg, but I must ask:·did the creature look·anything like this?
PG
Several comments here. asmov stands at teh bottom quite a long time, no doubt arguing with the programmer about doing the stairs.
He turns his head as he climbs the stairs, not a good idea!
When they put the screen up in front of the stairs why don't they just place him at the top manually, pull back the screen and shout "TADA!"
I won a contest earlier this year and got a penguin walking robot. I put it all together, callibrated everything and ran the demo program to make it use all its features and...
THE TILT SERVO WAS NOT MOVING!!
So, I emailed Parallax and they sent me a replacement (along with a nice UPENE ad
It sounds like it would end there, and I would happily chase the cats out of my room with a penguin making barking sounds, but NOOO...! Sure, the stride servo works all nice and dandy, but the tilt servo is wimpy... It just twitches back and forth and then suddenly jerks to vertical. I have to callibrate the servos every time so it doesn't jerk as much...
Happy now?
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
*-NEW-* SD Card Adapter·Now available!· Add extra memory to your next Propeller project with ease!
PG
You might want to consider a Multiplex Easy Star: http://www.rcgroups.com/forums/showthread.php?t=975833&highlight=easystar
It is made out of Elapor foam and is hard to break.
Just a thought.
TCIII
If you are going to send·a Robot·to save the world, you·better make sure it likes it the way it is!
Yep. I'm going to get one since I already have all the equipment. I also moved into my dorm last week, and there is a much better flying site available. It's even within walking distance, and doesn't have the excessive amount of obstructions that my last site had.
Rich H
The Servo Boss, a 12 channel servo tester kit from Gadget Gangster.
