has anyone built a hobby type pulse generator using prop or basic stamp — Parallax Forums
mikedivmikediv Posts: 825
edited 2009-08-27 18:05 in General Discussion
Hey guys I am in need of a fairly low end pulse generator I need to use with my HP1600A logic analyzer , I got it to work just using a prop and basically setting it up to output a square wave but I was wondering if anyone has somehting with a tad bit more options maybe even a GUI interface, I did buy that book on building your own electronics work bench but the pulse generator is way more complex than I need it also uses parts I do not have.
Thanks guys
    edited 2009-08-27 01:26
    What are your parameters? Rep rate? Min/max pulse width? Tell us more!
  • $WMc%$WMc% Posts: 1,884
    edited 2009-08-27 01:36
    milediv
    Try this link and just write your own signal generator.
    www.parallax.com/go/counters
    This is just back round code for the propeller, in any Cog.
    ___Think about it_____$WMc%___________
    The Truth is out there············································ BoogerWoods, FL. USA
    edited 2009-08-27 12:50
    I recommend driving a simple H-bridge using 2 output pins.
    This will let you do ac square wave pulses as well as dc and adds little complexity.
    You can build up an H-bridge from 6 small signal transistors, lots of schematics
    just google.
    - Some mornings I wake up cranky.....but usually I just let him sleep in -
  • RiJoRiRiJoRi Posts: 157
    edited 2009-08-27 13:53
    I designed a pulse generator using a BASIC Stamp -- it's at that awkward phase of putting it into a case.
    Basically, the firmware reads a 10-switch SPST DIP switch for the square wave pattern, and a 10-position BCD encoder switch for the frequency, and a DPST switch for HI/LO timing. The highest speed is 1mSec per pulse, and that took a lot of skull sweat to get out of the Stamp!
    Normally I would use a 555 timer with a pot if I just wanted a simple square wave, but I wanted to be able to have patterns like 0101101110.
    --Rich
  • mikedivmikediv Posts: 825
    Thanks Guys... RiJoRi that sounds good can you share your schematic and code???
    I did bread board a simple one with a 555 timer but it was just really a square wave output I could not change the frequency.
    Phil for immediate use the HP 1600A Logic analyzer requires a stable 10K clock input for slow stuff 0-10Meg but to read 10-20 Meg logic I need to be able to set the clock frequency
    anywhere from 9K-20 Meg depending and what speed logic I am measuring,, So I thought being able to change the clock output via switches or program options would be awesome , something like what RiJoRi described, Holly that's funny you suggested that because for Shts and grins to see if the HP even worked I used a PWM program for the prop I got off the Obex site. Of course it was just a fixed freq out but it did in fact work good enough for me to make sure the HP worked and it did, so now I figured it would be nice to build something a little more controllable.
    $WMc% Thank you I will check it out tonight when I get home, Oh by the way awesome car do you race it????? I live in CT it sucks because the close's track is 3 hours from me and on test and tune you are lucky if you get to make 2 runs after waiting all day and every single time I go some tuner will puke his guts out all over the track and lucky me gets that lane it should be a rule all tuners have to wear diapers if your going to be an Azz and try and stuff 300 HP shot of Nitrous into your little 4 banger then you have to wear an adult diaper LOL for your engine to LMAO
