need part number — Parallax Forums
need part number
mctriviamctrivia Posts: 3,772
edited 2009-08-30 01:20 in General Discussion
does anyone know the part number for these pins? I would like to use these or something similar for my super prop.
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
  • LeonLeon Posts: 7,620
    edited 2009-08-28 12:50
    Unless you want to buy vast amounts of them, you are out of luck. I make the board larger and use SIL turned-pins.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
    edited 2009-08-28 12:53
    Vast amounts of the part or bs2
    edited 2009-08-28 13:02
    Vast amounts of the connector pins! They also need special tooling, IIRC. There was another thread about them recently, you could try searching for it.
    Leon
    edited 2009-08-28 13:04
    Well I need a reel of 4000
    I can hand assemble for now until tooling economical.
    edited 2009-08-28 13:20
    Email somone at Parallax. They will tell you where they get them from.
    Leon
    Email someone at Parallax. They will tell you where they get them from.
    Leon
    edited 2009-08-28 13:24
    I sent kevin but he has not responded.
    edited 2009-08-29 00:52
    I remembered that Bean sells these via his site --
    http://www.hittconsulting.com/miscforsale.html
    edited 2009-08-29 01:01
    Thanks. $2/board is not to bad especially in such small quantitie
    edited 2009-08-29 02:00
    seems my board is to thick. says Dim (E)=1.32mm
    my board is 1.52mm thick. [noparse]:([/noparse]
  • jazzedjazzed Posts: 11,803
    edited 2009-08-29 03:52
    You might be ok with it. Bean mentions this in another thread:
    "They work best on 0.050" PCB, they will fit on a 0.062" board but it is a really tight fit.
    Let me know if you want to try some samples. I'll send you some. Just send me a PM."
    --Steve
    Propeller Tools
    edited 2009-08-29 05:00
    Tight fit probably means automating impossible but easy to hand solder. I do not have any prototypes yet but I think these look better then through hole pins and if not mistaken will fit in standard sockets.
    Have a datasheet? I need to know if rohs compliant and what recommended pcb footprint is.
  • hinvhinv Posts: 1,255
    edited 2009-08-30 00:50
    I would recommend them also. The through hole pins on my propmod really go into the breadboard quite hard. I am worried about wearing out the breadboard holes in the long term.
    BTW, what is the board thickness of the propmod?
    Just my 10 bits worth,
    Doug
    I agree will change propmod to use these headers
