Anyone using a DS1620 as a standalone thermostat per datasheet?
WBA Consulting
In the datasheet for the DS1620, it says its nonvolatile memory can be programmed with setpoints to run as a standalone thermostat (bottom half of page 4). I was wondering how well this actually worked. I want to make a temp controlled fan for my entertainment center and this looks like a good fit.
Andrew Williams
WBA Consulting
Andrew Williams
WBA Consulting
It works great. Be sure to avoid supplying power directly from the DS1620 to a load, e.g., DS1620 -> mosfet -> led/SSR, not directly DS1620 -> led/SSR.
Code example here.
Tracy Allen
www.emesystems.com
I concur with Tracy ; I have used this feature of the DS1620 in the attic to vent heat by controlling a fan.
Beau Schwabe
IC Layout Engineer
Andrew Williams
WBA Consulting
