I need of a soldering iron
So I've got my PCB's ordered and the components are coming, but I've tested soldering and desoldering 16 pin ttsop chips from an old phone with my rat-shack iron, and it's just not going to cut it.
I've been dreaming about this WD-1001 www.drillspot.com/products/74647/Weller_WD1001_Soldering_Station (yes I dream about soldering irons)
That will mean an extra week before I can get started, This is for a custom guitar that I've already blown loads of cash on and am getting anxious to have it done, and a bit to start programing it, but I need to know that the board works before I have it routed for it.
Anyway back to the story, I don't really want too just get a cheapy that won't last just to get this project done. Does anyone know of something that will do smd work well and will last but is cheap? Or should I wait to get a weller?
EDIT: I've found this that looks decent, I've heard bad things about their combo stations, so I don;t know if it will last, or has any accuracy at all. Aoyue 2900 store.sra-solder.com/product.php/6363/0
My jbc ad2700 has not needed replacement tips in 5 years even with heavy lead free soldering.
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
Greg
I'd like to disagree on both points. I have one of these, and I really like it. The engineering lab at my school also has one as their main iron, and it's lasted though years without ever hardly changing the tip. And you can change the tips hot.
@SexieWASD
Anyway, I'd recomend the iron that I linked, even over the on that you linked. In particular, it's smaller, easier to work with, and the numbers are easier to read from different display angles and lighting conditions.
www.antex.co.uk/product.asp?strParents=&CAT_ID=180&P_ID=965
Mike2545
This message sent to you on 100% recycled electrons.
I would get the Weller. Its well worth the investment.... If you Don't use crappy solider, You won't Smile-out the tips.
The Iron I have at work was purchased in 1987 and it still works today.I use it almost daily.
Another benefit of the Weller is if you do need a new tip, You can find one for it.
I do remember changing the tip on the Weller, But it was years ago!
And finally, its made in USA!!!!
You'll like the Weller, Be sure to read the DOC.s that it comes with.
_______$WMc%______
The Truth is out there············································ BoogerWoods, FL. USA
http://www.howardelectronics.com/xytronic/169D.html
I have this soldering station for about 4 year now and had to replace the tip once a year
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 8/27/2009 3:57:32 AM GMT
Their tips are very high quality, made in Japan and last a long time, with a large selection of styles.· They seem to be well known in commercial gear.
I'm sure Weller makes some good equipment, but they seem a bit more expensive than some alternatives that are equally good if not better.
Post Edited (Agent420) : 8/27/2009 10:54:24 AM GMT
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
I seem to be having a hard time finding trustworthy online stores that carry JBC, anyone have a link?
I like the idea of a dual power station so I can have one fine tip and a normal/large tip on two pens at the same time.
I couldn't afford a second pen+tip at the same time though [noparse]:([/noparse]
It would solve the changing tip hot problem though
A second-hand Metcal system will cost about the same as a new Weller, and is very much nicer. The newer MX-500 power unit supports two handpieces, but only one can be on at one time. Many people just buy two used STSS power units (about $100 or less) so that they can have two different tips powered up at the same time.
Leon
Post Edited (Leon) : 8/28/2009 12:46:08 PM GMT
http://www.howardelectronics.com/jbc/ad2700.html
Interesting metcal is ir.
Takes 2 seconds for my 50w to heat up. I like that when you put on stand drops to half temp or off depending where you put it.
I imagine in a production environment that might be useful, and it would keep employees from being able to fiddle with the settings (seems a common problem, as many adjustable stations offer a lockout feature to aid that).
But in a varied home-use environment, I would personally find that limiting.· If I am working on a project board, and need to solder both some ic's and then sockets or connectors, pots or other items (or brute force desoldering) that might require a higher temperature, I prefer the option to set the temp as I need it without having to resort to changing cartridges.· I've only swapped the tip once on my XYtronic over the years, because it finally became worn out (chipped more than lost plating, and that from misuse trying to scavange parts).
I used to have an older Weller fixed temp station, and it drove me nuts.
Post Edited (Agent420) : 8/28/2009 3:37:40 PM GMT
Leon
Post Edited (Leon) : 8/28/2009 3:50:49 PM GMT
lol...· I guess the same method I use to set the temp on my portable propane iron.··Burning fingertips have a particular odor precisely at 250 C ·
Not that I wouldn't like a Metcal, I just think that for the home hobbiest an adjustable station is more affordable than investing in several cartridges for different temperature needs.
I guess I'm just a hack ;-)
-5xx for 500F
-0xx for 600F
-1xx for 700F
-8xx for 800F
Different temperatures aren't needed unless one changes from leaded to lead-free solder.
Leon
Post Edited (Leon) : 8/28/2009 5:25:15 PM GMT
Out of curiosity I looked up those Metcal tips...· Is it correct that each tip is a specified temperature?· So where I have perhaps 4 styles of tips (small / big chisel, conical, bent) that I can use at any temperature, you would need each physical tip style in several temperature ratings?· That seems like a substantial investment.
edit -
I guess I'm confused on the single temperature thing.· When I'm soldering power wires onto big lugs, it seems I need a higher temperature to accommodate it's thermal mass than when I'm doing fine board work.
Assuming I am using leaded solder, I only need a small number of cartridges with different tips for nearly every soldering job, but they all use the same temperature.
Leon
Like Leon said "You don't understand soldering."
If Your trying to mass produce a product by soldering them by hand,You will not be competitive. A 13 year old Malaysian Girl will out solder you in a heartbeat...Besides running a re-flow oven/tank and some other methods of soldering.
If Your doing development work, use two or more irons with deferent tips....
I recommend the Weller
__________$WMc%__________
OK so I have gone through all of the differences between the Weller and the Metcal, and I must say that there isn't that much of a difference between the two, but only because of the WMRP pencil for the Weller, it's a ripoff of what all of Metcal's pens are, only with better tip swapping, but not as high power, and the rest of the pens aren't near as good.
There does seam to be one difference as far as I know, The Weller has much more power than a MX5000. With the Weller it can combine the two channels to power one pen, so 150W pens are available which could be handy to have around.
Who knew that choosing an iron would be so hard? basically it's one really nice pen for smd, and just ok pens for everything else, or nice pens for everything, but no option for big stuff.
[noparse][[/noparse]edit #1]
@ $WMc%
I'm just messing about really, this is just hobby work.
[noparse][[/noparse]edit #2]
I think I have decided on the MX5010, and the "ultra fine" pen down the road, and a Weller solder gun if I run into any heatsinks. It's the tip selection that made the most difference. Metcal has a ton more choices than Weller does.
Thanks, leon you helped make things a bit more clear on what the more important features were.
Post Edited (SexieWASD) : 8/29/2009 3:31:04 AM GMT
