more than 15 parameters to pass to a cog?
I need to pass more than 15 parameters to a cog. Can this be done?
Cog.start (_ff, _Tf, _X0, _X1, _Y0, _Y1, _Vr2, _aR1, _aR2, _Pb1, _Pb2, _Pb3, _Ab1, _Ab2, _Ab3,_kb1, _kb2, _kb3, _max, _min, _all)
--Steve
Propeller Tools
You can also copy the parameters in the Spin start method like:
Post Edited (Mike Green) : 8/25/2009 7:24:42 PM GMT
Either way you go, it will be painful though ... unless your interface parameters lose weight [noparse]:)[/noparse]
You could use a generic buffer instead and provide methods to do get/set on the parameters.
--Steve
Propeller Tools
Bad, bad, bad, no, no, no!
You are passing the long address of a set of parameters on the stack. By the time the cog has loaded the spin routine will have returned and possibly damaged the stack contents. Don't do this.
lt's not particularly silly, is it?
But I'd be much more inclined just to do a longmove from @_ff to a parallel area in the DAT section before doing the cognew.
Post Edited (Phil Pilgrim (PhiPi)) : 8/26/2009 1:40:15 AM GMT
I usually add a delay after cognew or poll for the cog to finish in my code to make sure the cog loads before i try to use it. For example, even doing the RightThing(tm) as in FullDuplexSerial and not waiting for it to load before calling fd.str(string("Hello")) pretty much guarantees output failure. Shrug shoulders [noparse]:)[/noparse]
So, Is Python really named after Monty Python?
--Steve
Propeller Tools
