prop to prop comms
Guns of Fun
Whould there be any speed advantage to having two props communicate over an 8 I/O bus, instead of I2C or simple serial?
Is there anyone who is making multi prop boards that communicate over an 8bit bus?
I have the beginnings of the design wired on my desk so that I could start software, but I have been distracted by other things.
--Steve
Propeller Tools
Do you really need an extreme rate of speed?
The prop can transmit (and presumably receive) at over 1 Mega bit per second. And if you get fancy with two cogs (have not implemented this yet) perhaps two to three times that fast.
Keeps the hardware a lot simpler than a parallel bus.
Cheers,
Peter (pjv)
Here is something I put together awhile back that still should be cleaned up and put in the OBEX but I haven't had a chance to do yet. It was designed specifically to allow fast communication between two Propellers. Using only 4 pins you can achieve 14.5 Meg Baud which is the same as saying 14.5 million bits per second.
http://forums.parallax.com/showthread.php?p=694610
With a little bit of handshaking you could make this bidirectional. The main thing to consider is that the receiver is up and running before you transmit, or you will lose data. When I was testing this object I used two propellers connected using a 5 conductor ribbon cable(4-signal, 1-ground), no shielding, and 10 feet long. I did this on purpose so that (I felt anyway) it would work under an extreme condition. Both props also need to be running at the same clock frequency, but they don't need to be locked or synced together. They each can have an independent crystal. The way that the data packets are sent, (using two start bits) allow it to lock on the signal.
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 8/25/2009 3:15:49 AM GMT
Im not an electrical or software engineer, but I drew this up on expresspcb.
I was thinking of 4 props communicating·with each other·over an 8bit bus.
I have no idea what some of the software guys could do with this.
I was also thinking that a couple of cogs in each prop could be tasks for communication purposes.
Its not an 8 bit bus.
It would be a parallel bus of 8 lines at 32bits each?· So 256 bits at a time?
Am I close?
BTW: Welcome to the Propeller forum.
--Steve
Propeller Tools
The problem I see in the pcb layout is that there is no room for the EEPROM and you are limited to using only 4 Props.
If you have a Buss between each Prop, where only 1 Prop can be a 'Master' and all the rest are 'Slaves' you can use many Props. At any time you can use a single wire (<-standard serial connection), 4-wires, 8-wires, or whatever to communicate to all of the 'Slaves' at once. Through software you can negotiate for a 'Slave' Prop to become a 'Master' and suppress the current 'Master' into a 'Slave' if it's necessary. Using a buss configuration to connect multiple Props, each Prop would have its own address, either hard coded through some extra I/O pins, or programmed in software. This way, the 'Master' can send a signal where all of the other Props listen as 'Slaves'. Based on the command and the requested Prop address sent from the 'Master'... all, some, or just one Prop can act on the command.
Beau Schwabe
IC Layout Engineer
3-cogs on each prop for full duplex.
Not too.. ,,, Schwabe ?
Now I suppose the only thing to be concerned about is multiple cog access to said memory locations?
This where lock semaphores come handy?
http://forums.parallax.com/forums/default.aspx?f=25&m=343952
mctrivia and others worked up a board design for 8 props. I think mctrivia is just waiting for enough interest for people to join in.
I was thinking of a similar design to yours that I called propGrid. I wouldn't use cross links like you have for point to point access from each prop because it used up too many pins and wasn't scalable.
If you used an 8bit link to your neighbor props, you would have 16 available I/Os on each corner prop, and only use the center ones for processing, message passing, and the available memory.
The downside(or upside depending on how you looked at it) is that the props in the center would certainly have to boot off of their neighbor. I consider this a plus because you wouldn't need a eeprom for each.
If you run on the same clock, you might be able to eliminate one of the start bits which would raise your throughput.
WoW! 8 props on a single board
I know you can't hook a single xtal to more than 1 prop, but I wonder if
instead of having 8 xtals on the board and thus having no precise sync
between the 8 props, if you could take 1 xtal and build an amplified oscillator
circuit on the board somewhere and then just route the output from that oscillator
to all 8 props?
Has anyone done something like that?
If it's a silly idea don't laugh, I'm 99% software and 1% hardware...a total
hardware noob
@Guns of Fun
I suppose that is you in your avatar image?
It looks like you are aiming something...what is
that big thing you are aiming???
- Some mornings I wake up cranky.....but usually I just let him sleep in -
Really?
So I guess it wasn't a silly idea then
Hi Holly
What you see in the avatar is me riding backwards on top of a big truck at 75mph.··I am carrying the M249 (SAW), and dog gone it, none of the bad guys would ever come out and play.
Nope, I'm pretty sure I have seen some other designs that use a prop output and a cog counter to provide the clock to another prop. I think the Morpheus board does that IIRC. Now I'll have to go look again. Not a far fetched idea at all.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Post Edited (Leon) : 8/25/2009 2:30:47 PM GMT
Can you post a link to that info?
www.xmos.com/search/node/xsystem.pdf
You need Section 3. Someone on the Xlinkers forum has interfaced the two-wire link to an FPGA. His Verilog code is available.
10 wires are in fact needed for bi-directional transfers. It would obviously make sense to try the two wire version first.
Leon
Post Edited (Leon) : 8/25/2009 6:30:21 PM GMT
That's actually pretty slick! In a way it's like Rectangular QAM only your constellation symbols are designated to specific wires and not quadrants. I tried to do something like this by adjusting the width of the pulse not only for the on-time, but also for the off-time. The specific width then became the constellation symbol where the on-time would represent I for example, and the off-time would represent Q.
This method opens up an interesting possibility that would be much faster than the high speed driver I have posted.
Thanks Leon
QAM reference:
en.wikipedia.org/wiki/Quadrature_amplitude_modulation
Beau Schwabe
IC Layout Engineer
Leon
Post Edited (Leon) : 8/25/2009 7:36:39 PM GMT
I think your on/off time thing should work. But probably, at least for lines with anything more than a token amount of capacitance or distance, you would also need to send the complement. All of course to keep the DC balance neutral, like Manchester coding does.
Interesting concept.... must try this.
Cheers,
Peter (pjv)
Morpheus and Propteus are designed to have a shared bus - their P0-P7 stack directly on top of each other - NOT and accident. If the SPI ram using P8-P11 is not populated, P8-P11 are available for handshaking; if it is populated, P9-P11 are available when P8 is high.
Please note you really should only put a Mem+ boards onto the top Morpheus onto such a stack, and they cannot have the SPIO and SD sections poulated.
I have not written any software for it yet, it is on the list - I intend to write an app note on this configuration. Due to bus loading I don't recommend stacks more than 10 high.
Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
Morpheus & Mem+dual Prop SBC w/ 512KB kit $119.95, 2MB memory IO board kit $89.95, both kits $189.95
www.mikronauts.com - my site 6.250MHz custom Crystals for running Propellers at 100MHz
Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
Thanks ... I think that at one time I calculated that I could send the varying widths ok with 50ns pulse resolutions (This was with a 4X4 symbol table). But receiving and decoding became an issue and I didn't gain any real speed. I hadn't thought of using the individual pins to represent symbols - wow!
.. but feel free to explore that option... I hope that your mileage will vary, and share your results!
Beau Schwabe
IC Layout Engineer
