2 set of Boe Bot running with 2 identical pairs of Tx and Rx
Hi, I am trying to setup a racing game using 2 Boe Bot. They are controlled via wireless communication using the parallax Transmitters and Receivers. as in one Boe bot with Rx controlled by one BS2 with a Tx, and there will be another identical set. I have programmed such that one Rx will wait for "!", and the other Rx will wait for "?". There is a pulseout of 1200 from each Tx and a short pause of 10ms. However, there is a big problem as the frequency of both pair of Tx and Rx are the same and they interferred with each other. Is there any other way around this? thanks in advance.
quekyt
quekyt
Tia'Shar Manetheren
Parallax Engineering
It's not the modules, it's physics that are the problem. Unless you get some more advanced modules that automatically do interference detection and frequency hopping, you'll need to come up with a solution that works for your project. If it's not feasible to take out one transmitter, you'll probably have to add two receivers. Of course, you could get another pair on a different frequency from somewhere.
