Controlling HHO Generator
I know this is similar to driving the DC motor thread but I think it warrants its own thread ?
I have a PWM Pal which I would like to use to power a Hydrogen generator with up to 40 Amps from the Car Battery
The trick is to keep it under 30 Amps
The problem is that as the generator heats up it wants to draw more Amps.
I wanted to use a temperature sensor to then back off the Duty Cycle so as to not exceed a maximum temperature (say 50 deg C)
Do you think this is possible with the stamp ?
Don't worry. Be happy
- Stephen
Now anyone know what mosfets I need and what circuit I need to drive them ???
....and make sure they dont draw more than 30 Amps...
P.S. You can see that I electronics is not my strong point. Sorry.
