Anyone seen a source for cheap VGA monitors. — Parallax Forums
HollyMinkowskiHollyMinkowski Posts: 1,398
edited 2009-08-26 05:56 in General Discussion
I need about 60 of them.
Small ones preferred (13-15inch... 17inch max), 4:3 aspect preferred, external 12vdc switching pwr supply preferred to internal supply.
In these days of huge, wide aspect VGA monitors smaller 4:3 monitors have suddenly become scarce.
- Some mornings I wake up cranky.....but usually I just let him sleep in -
    edited 2009-08-22 20:31
    Holly, not sure what you consider cheap, but check the local computer parts suppliers. I got several 15" monitors for $90.00 (Canadian ~72.00 US) from my local distributor. Have not seen any new monitors smaller than that for a long time. If used is ok I would suggest checking with computer stores and retailers that do upgrades. They may have trade ins in that size range.
    edited 2009-08-22 20:59
  • John AbshierJohn Abshier Posts: 1,116
    edited 2009-08-22 23:54
    I picked up a 10-11 inch tv from my local big box furniture store for $99. TV tuner, composite in, svhs in, vga in. Wide screen format but will switch to 4:3 with side black bars.
    John Abshier
    edited 2009-08-23 19:12
    Check your local Craigslist, unless you need all-identical units. Ever since plasma & LCD TVs & monitors came out, people are firesale-ing or giving away their perfectly good CRT monitors for no great reason other than size & style. CRT monitors have a better picture, don't cause headaches, and will outlast plasma/LCD TVs & monitors by a factor of 4 or more. Leave a new monitor on 24/7 like we used out CRTs and see how long they last. I just got a mint Viewsonic A75f 17" flatscreen CRT monitor with a perfect, gorgeous picture for $15 off CL.
  • vaclav_salvaclav_sal Posts: 451
    edited 2009-08-23 19:30
    Where do you·want them ? I live near·"surplus" ·store and they have them by truckload.
    Houston TX
    edited 2009-08-23 23:57
    John Abshier said...
    John Abshier
    @John,
    Would you mind sharing the details? Brand Name and Model?
    OBC
    New to the Propeller?
    edited 2009-08-24 12:13
    What we need are VGA monitors that are new, in-box, smallish, 4:3 preferred, external 12v brick preferred.
    I should have mentioned the new, in box part I guess, my bad. Just would look cheap to deliver a package of
    all new stuff to someone but have an old surplus monitor stuck in there.
    I was wanting to power the remote terminal board as well as the VGA from the 12v brick to save about $5.
    I found some 17" new, wide screen with external 12v brick for about 107.00 delivered when that quantity bought.
    That may be the best I can manage.... anyhow I saved the expense and eventual hassle of supplying a cheap
    laptop or netbook with each package so 102.00 is not so bad. (107.00 - 5.00)
    @Phil Pilgrim
  • mikedivmikediv Posts: 825
    edited 2009-08-26 00:41
    Holly believe it or not the small monitors are more money and the older and smaller the more costly I needed, need a cheap mono chrome 9 pin TTL monitor you know the ones we threw out by the truck loads now I need one and can not find one used with burn in badly for under 120 bucks with no guarantee they work,,, how's that for "this blows" anyway I know a place down here in CT they have 35 brand new 14 inch Apple VGA monitors I asked but they do not know if or when they would ever get more but I know the owner
    he said make an offer if you are interested give me a call or email me and I can help you get in touch with them its a surplus house but I live not to far so I could check them out for you I do not know if they come with any kind of warranty but they do have external power supplies
    Ran into the same problem about a year ago trying to source 15" 12v displays for low power computing stations for a company called Inveneo. They didn't have much luck other than sourcing straight to China. The last round of builds was done using displays from a company called "Perfect Display" and they used NEC and Sharp panels in their displays. They were very supportive to quality issues. I dug through some old email and found the following contact info, might be worth a shot.
    David He
    Perfect Display Technology Co., Ltd
    Email:davidh888@gmail.com
    Phone: 86-13246732099
    The pricing was in the $110-120 range and that was a year ago. Through a little research, I found it would have been cost effective to buy panels and have chassis' made locally for their needs if they bought over 200. They are a non-profit company, so they couldn't justify the design costs of there own units. Smaller panels are still very easy to get and driver boards are even easier.
    Andrew Williams
    WBA Consulting
