The Last DIP Propeller in the world ?
Yesterday I happened to be in the Helsinki branch of the Scandinavian electronics distributor Elfa.
Out of curiosity I asked if Elfa had any DIP Props in stock. Normally they don't keep chips and such here but get them sent over from the Stockholm branch. Well blimey, Elfa had one last Prop in stock and it was in Helsinki.
So of course I had to slap down my money and snag it immediately. Total 16.35 Euro bloody hell.
Just to taunt you all here is a picture of it fresh out of it's packaging and settling down in a breadboard.
Now I can get on with building my TriBlade.
Any other sightings out there ?
uk.farnell.com/jsp/search/browse.jsp?N=500006+1004406&Ntk=gensearch_001&Ntt=propeller&Ntx=
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
I think it may be time for making more modules! I especially like the propmods...
Sure, the DIP chip is convenient for breadboards and such, but modules seem even better for their other features that would take up precious real estate on one's breadboard/circuit board.
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
*-NEW-* SD Card Adapter·Now available!· Add extra memory to your next Propeller project with ease!
Ain't gadetry a wonderful thing?
aka G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
the shop-site says
Item code P8X32A-D40
Availability Product is expected to ship on 11/5/2009
best regards
Stefan
Normally I would opt for the QFP or QFN package, but I had a special request to avoid surface mount devices.
I thought for sure Digi-Key had more, but alas I just checked and they are out.
You could put always put a QFP on a SM adapter board (like what I had to do for the FT232 which isn't available in DIP).
As StefanL38 noted, the Parallax site says they will ship again in November. Is that right?
Well, I have 10 actually as the two that are on the remote terminal project test boards
are in zif sockets and can be lifted out if needed. Sure glad we bought some as
I'd have a hard time using the sm versions on breadboards
BTW: The 2-wire remote terminal boards work fine and the data passes easily on the power
lines at a respectable distance. I am testing them by hooking them up through a roll of
bulk ethernet cable, that way the terminal board is right next to me on the table even though
it's many yards of power wire away. I hooked it up at first with old rg58 network wire that
was under the floor to a vga/kbrd setup in a room down the hall but then it struck me how silly
that was and I used the roll of wire
coming through all right! Doh!
- Some mornings I wake up cranky.....but usually I just let him sleep in -
Crazy guys took the drum up to the lab in the lift, way over it's weight limit. After that the lift was always 6 inches down from the floor it stopped at.
Our DSLs worked fine.
Now that was one big roll of wire!
My roll is just 100ft but I have hooked up the wires in the ethernet cable so it loops back
and works like 200ft...it also worked wired as 400ft but I had to increase the V a little...the
wires in that cable are pretty small diameter and don't carry current so well.
